Home > Technical (L322) > Torque convertor ( supplier question)
Rewmer
Ive accepted that I need mine replacing - rev fluctuation, cattle grid effect etc and Ive been looking around a various places. J Pat and Sussex autos seem to be the favorites. But then i came across this ad in ebay
http://www.ebay.co.uk/itm/Range-Rover-L322...Sw9r1V-X2f
He talks about uprated kevlar friction ring.
Anyone have any experiance of this guy or comments? No7 - 2003 V8 Vogue
Post #412384 6th Nov 2016 6:01pm
davidsmith1307
Worth asking RRPhil on here!
Post #412388 6th Nov 2016 6:19pm
Rewmer
I got the leads for jpat and Sussex from Phill, I hoped someone from here had fitted one and had some feedback No7 - 2003 V8 Vogue
Post #412394 6th Nov 2016 6:51pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Can't really see the point in paying another £200 on top of the price I paid for mine from Sussex Auto for extra lifespan given the lifespan of my original was 100k+ miles and even then wasn't worn out (replaced as I took the gearbox off for another issue). It's likely my gearbox will need a rebuild before the replacement torque converter wears out.
It all depends on how many miles you do, whether you do a lot of towing and how long you are planning on keeping it, personally I would save my money (and put it towards the next thing to wear out!).
Post #412396 6th Nov 2016 7:12pm
RRPhil
I agree that it would be very interesting to hear from anyone who’s tried one of these converters.
My first thoughts were whether the friction coefficient of the Kevlar friction material would be the same as the resin-bonded paper used in the standard Sachs unit. If not, the transmission controller would have to learn the new LUC settings in ‘controlled slip’ mode – assuming that they’re within its range.
I completely agree with Weejock that the original friction plates generally last beyond 100,000 miles anyway so the only potential benefit would be once the vehicle had exceeded 200k miles.
Phil
Post #412477 7th Nov 2016 1:03am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
It seems Doug also repairs & sells all Tefal Activfry machines, does it make me a bad person that all I can see is a torque converter!!!
Post #412880 10th Nov 2016 12:59am
miggit
I had one of those... I got 25 miles out of it before it destroyed it's self and my gearbox too Shocked
And we had the blame game afterwards... lets just say that I wasn't totally out of pocket... but it did cost me an arm and a leg. In the end i went for a totally new unit supplied and fitted by STA in aylesbury... FYI it wasn't that much more expensive that a recon converter... but it helped my piece of mind Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412882 10th Nov 2016 1:05am
miggit
Oh and another lesson learnt, you can't just fit a new / recon converter... only you start playing with the gearbox it really needs to be stripped and cleaned if nothing else, cos your worn out converter will have dumped a lot of grinding past in to the rest of the box.... it will sit there forever until you do something like change the oil... then it gets softened up and goes on a wrecking spree Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #412884 10th Nov 2016 1:14am
holidaychicken
Do you have the TD6 and if so was the valve block checked before fitting the carbon fibre TC, just out of interest ?
Post #412886 10th Nov 2016 2:42am
miggit
First time the gearbox was power flushed.... second time the whole box was stripped and cleaned, and the valves were replaced with Sonnax upgrades... should have been done first time around Sad
And yes it was the TD6, which is by far the weakest gearbox.. but it works in the same way that the ZF unit does, only worse Laughing But knowing what I know now, there is no way that I would replace a major component on a "sealed for life" gearbox with out a full strip down and clean... because the fluid stays in the box 3-4 times longer that normal all the muck from the friction materials wearing has to collect some where.. it forms pockets of nastiness waiting to be released by new fluid Shocked and then Big Cry starts.......... Yesterday I couldn't spell Engineer... Today I are one!
Post #412905 10th Nov 2016 11:22am
holidaychicken
So when the carbon fibre TC failed, was that the first time before the strip down and new sonnax valves?
Post #412996 10th Nov 2016 8:46pm
Rewmer
Proper one it is then. Diint think about checking out the other items for sale. Never would have put TCs and fryers in the same service supply area 🙀 No7 - 2003 V8 Vogue
Post #412998 10th Nov 2016 9:04pm
miggit
Shocked err not carbon fibre..Kevlar....
It sort of went like this 100K rebuilt gearbox... 122 K gearbox showing signs of TCC failure.. So new Kevlar TCC was got, but full power flush before the new converter was fitted... 25 miles later Kevlar converter let go Shocked Then had the valves rebuilt, as they were suspected, "couldn't possibly be the converter"
Whistle Well it bloody was Evil or Very Mad
Had the gearbox stripped, new converter fitted and everything cleaned and checked... now working OK, but should have saved myself the hassle and just had the rebuild in the first place.
Unfortunately the sealed for life bit is the killer on these boxes... as everything wears the muck keeps getting sent around the box, causing more damage as it goes... the older boxes that had an oil change every 2 years were way better lasting Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #413004 10th Nov 2016 9:20pm
holidaychicken
Sorry kevlar, I think the main killer is the valve body wear and then it seems common to replace / repair everything except the root cause which is the valve body and then in what can be a very short time, failure again caused by the lack of pressure to the LUC.
luckily i have a 4.4 petrol so the ZF box is far more forgiving than the GM when it comes to the TC failure.
Post #413029 10th Nov 2016 11:30pm
miggit
Not so sure that the ZF suffers in quite the same way, being built by the Germans who care about quality, rather than the French who care about dinner Shocked Laughing But I still reckon that if the TCC is fubar'd then it's a good idea to have the rest of the gearbox checked and cleaned if nothing else.. after all you've already paid to remove the box, it don't take that much longer to strip it and give it a wash. What you have to bare in mind is there will be a lot of crap, in the form of worn friction material, that will have come out of the TCC... If any is left in the gearbox then it will shorten the life of it.. I'm not saying just book it in for a rebuild, it might not need it, but have it properly cleaned and inspected before you make that decision.. If you have a good gearbox centre then they should be happy to do that, I know that STA Aylesbury will do that. When they got mine all apart they could have said it was knackered, but it wasn't, as it was 22k old, but it did need a really good clean as there was tons of swarf from the TCC going tits up Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #413032 10th Nov 2016 11:53pm
