![]() | Home > Technical (L322) > Cold start |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Cold start is automatic and clever. The ECU monitors both exterior and engine coolant temp and uses the relevant fuel mapping. It also causes an auto to hold onto lower gears for longer to warm up the box fluid.
Tomj Member Since: 06 May 2012 Location: Surrey Posts: 2 ![]() ![]() |
Ah OK thanks for the advice. I'll check that out. Just wanted to make sure I hadn't bought a lemon with a dodgy starter.
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 ![]() ![]() ![]() |
"Cold start is automatic and clever. The ECU monitors both exterior and engine coolant temp and uses the relevant fuel mapping. It also causes an auto to hold onto lower gears for longer to warm up the box fluid".
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for getting worried over the years being held onto longer first thing in the morning. Really pleased to read that post 😄 2015 4.4 AB
