Home > Technical (L322) > Cold start
Tomj
Cold start
Hi, I've got a silly question to ask. I'm about to buy a Range Rover autobiography on a 59 plate. Two questions is there such a thing as a cold start button. I.e. When you press the start button on a cold morning there is a delay before the end roars to life.
The other question is that I thought that a 59 plate was a 2009 model? Yet the exterior of the car looks like a 2010 model? I ask because I'm going refresh some of the outter trimming.
Any advice greatly appreciated.
Thanks.
Tom
Post #412591 7th Nov 2016 9:03pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Cold start is automatic and clever. The ECU monitors both exterior and engine coolant temp and uses the relevant fuel mapping. It also causes an auto to hold onto lower gears for longer to warm up the box fluid.
You can check the model year from the VIN.
Usually, a model year is available from the previous October to the actual year and the plate number doesn't change until March. For example, my '07 MY has a 56 plate.
Post #412635 8th Nov 2016 11:37am
Tomj
Ah OK thanks for the advice. I'll check that out. Just wanted to make sure I hadn't bought a lemon with a dodgy starter.
Thanks again.
Post #412636 8th Nov 2016 11:45am
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
"Cold start is automatic and clever. The ECU monitors both exterior and engine coolant temp and uses the relevant fuel mapping. It also causes an auto to hold onto lower gears for longer to warm up the box fluid".
I had noticed this the last 2 mornings, felt like it was in sport mode. Was starting to get worried there was a problem looming!.
Big sigh of relief Not Galway but Balmoral green actually
148,000 miles
Post #412649 8th Nov 2016 2:23pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
+1 for getting worried over the years being held onto longer first thing in the morning. Really pleased to read that post 😄 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #412670 8th Nov 2016 6:14pm
