![]() | Home > Technical (L322) > PDC Module - Need Help |
Can I send someone my PDC module to test pls?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Dan, you can use mine if you like when I come over for the electrics? Is it the same ..... mine only being a lowly HSE an' all?? |
hi dan, send it to me ...no probs V8 facelift Range Rover Autobiography 22" wheels.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
doesn't matter which MY as it is the same from BMW through to Facelift models. I'll test it if you want to drive up to Lyneham...
hi dan, sounds like stevegt is your man.. |
Thanks for the offers guys, I guess it would make sense to pike your brains Steve - I'll drop you a PM.
Dan i am here on Saturday adn early Sunday am (til 12) |
Cool, might treck over to yours on Sat late afternoon then if thats any good? ![]() |
Sat sounds ace! will chill the beers! Or should that be defrost?? |
Just an update to close this off. I bought a random BMW PDC ECU because it "looked right" turns out it works fine and I now have fully functioning PDC.
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Did the backs work and just the fronts not. Non of mine work and i have one wire that i knows not connected on the front due to me stripping wire but they never have worked since i got it. would one wire stop whole system, Might take a gamble on this unit (mines 2002) Look ok?
You can have my old module if you want - only the rears worked with it. If you want to just test it?
Going to wire the broken sensor wire back up tomorrow and go from there i think. May take you up on that though Dan. |
