![]() | Home > Technical (L322) > p0000 fault code? |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479
No idea at all but I've had the same for a while.... |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I take it yours wont clear either? I'm going to try a battery reset as I've just been informed it could be a glitch. Failing that I've a new upgraded thermostat to fit and hopefully that sorts it out... |
I was considering the thermostat mod to try to clear the fault. Let me know if yours works |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
The thermostat mod won't clear the fault...
I get ya ! ...any idea what could be triggering the fault then ? Car was fine until today until it started idling at 900rpm...that only stopped after I restarted car then fault appeared..only thing I've done to the car before it appeared was to leave a daft phone charger in the cigar socket for a few hours to see if its led switches off after cars asleep...obviously not related...do you think its worthwhile doing a battery reset? Cheers pete |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
That's odd, I did the thermostat hack / upgrade and I get this fault now,
It could be a fault within the thermostat but I doubt it, I really wouldn't worry about it and I doubt it has much to do with the engine revs, mine tends to wander around on these cold days, I recon it's something to do with the different air density as the temp drops but that's just my own theory...
Funny you should say that..its been damp and freezing up here today.. Worse day if the year and this fault shows. Will keep an eye in it anyhoo...thanks gents |
Have you had a look inside the thermostat plug? There's been posts on here about them melting and corroding inside near the contacts causing faults.
I'm going to have a peak at the weekend when I'm off...is it easy to access plug or do I have to remove the air plenum ect ? |
Probably best to remove the plastic engine cover and the air intake pipe from the air filter housing, not even a two minute job |
Brilliant! Will check that just to be sure...thanks |
| All times are GMT |
