Home > Technical (L322) > p0000 fault code?
alistairh
p0000 fault code?
started the fatty earlier and noticed she was idling a lot higher(900rpm) switched ignition off and re started it and it went back to its usual 600rpm with air con switched on....out with my I carsoft and the engines showing a fault that reads" Electric thermostat circuit fault last occurrence plausibility ? Everytime I clear the fault it returns.. Any ideas guys?
Post #412817 9th Nov 2016 5:52pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
No idea at all but I've had the same for a while....
Post #412823 9th Nov 2016 6:24pm
alistairh
I take it yours wont clear either? I'm going to try a battery reset as I've just been informed it could be a glitch. Failing that I've a new upgraded thermostat to fit and hopefully that sorts it out...
Post #412827 9th Nov 2016 7:16pm
chris_read
I was considering the thermostat mod to try to clear the fault. Let me know if yours works Thumbs Up
Post #412828 9th Nov 2016 7:31pm
The thermostat mod won't clear the fault...
It will put up this code...
0x48D Engine cooling fan control fault
It does not create a bong or put the engine light on
It is irrelevant and doesn't effect anything else, it is just a control and not a sensor... Thumbs Up Pete
Post #412838 9th Nov 2016 8:32pm
alistairh
I get ya ! ...any idea what could be triggering the fault then ? Car was fine until today until it started idling at 900rpm...that only stopped after I restarted car then fault appeared..only thing I've done to the car before it appeared was to leave a daft phone charger in the cigar socket for a few hours to see if its led switches off after cars asleep...obviously not related...do you think its worthwhile doing a battery reset? Cheers pete
Post #412842 9th Nov 2016 9:00pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
That's odd, I did the thermostat hack / upgrade and I get this fault now,
0x48C Electric thermostat circuit fault
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #412847 9th Nov 2016 9:21pm
It could be a fault within the thermostat but I doubt it, I really wouldn't worry about it and I doubt it has much to do with the engine revs, mine tends to wander around on these cold days, I recon it's something to do with the different air density as the temp drops but that's just my own theory...
As long as it pulls cleanly then I'm happy... Thumbs Up Pete
Post #412848 9th Nov 2016 9:33pm
alistairh
Funny you should say that..its been damp and freezing up here today.. Worse day if the year and this fault shows. Will keep an eye in it anyhoo...thanks gents Thumbs Up
Post #412849 9th Nov 2016 9:38pm
UK Marine
Have you had a look inside the thermostat plug? There's been posts on here about them melting and corroding inside near the contacts causing faults.
Simon
Post #412850 9th Nov 2016 9:45pm
alistairh
I'm going to have a peak at the weekend when I'm off...is it easy to access plug or do I have to remove the air plenum ect ?
Post #412851 9th Nov 2016 9:59pm
UK Marine
Probably best to remove the plastic engine cover and the air intake pipe from the air filter housing, not even a two minute job Thumbs Up ______________________________
Simon
Post #412853 9th Nov 2016 10:02pm
alistairh
Brilliant! Will check that just to be sure...thanks Thumbs Up
Post #412856 9th Nov 2016 10:15pm
