Home > In Car Electronics (L322) > My 07 vogue SE , Bluetooth music ??
Stew 46
England 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Morning chaps , how can I Bluetooth my music from my iPhone or iPad with out an aux lead ? , and when I use lead I only get half volume ?? , stew 07 VSE
Post #413466 14th Nov 2016 10:03am
smartone
2003 Range Rover Autobiography 4.4 V8 Java Black
There are gadgets that you can buy on ebay, or via eBay you can have them wired into your unit in the boot to allow this.
Be warned, mine worked well for about 2 years, then it developed an electrical fault, and caught fire, burnt all the wiring loom and this wrote off the car! My 13 year old L322 was replaced with a 2011 L322, (albeit with more cash), happy days.
Post #413467 14th Nov 2016 10:07am
miggit
Whistle Wont work Whistle
Your car is a 2007 which is a different system to the 2003....
Some 2005 cars have a usb plug in the centre console, in the back, and I believe that you can plug a bluetooth adapter into that... If you don't have said plug then you'll need to fit the aux adaptor... which for cars with the MOST system ain't cheep... infact I recommend that you are sitting down when you look in to prices Laughing And then I'm not entirely sure if that will give you a digital input, got a feeling that it will be a 3.5mm jack plug only Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #413492 14th Nov 2016 12:19pm
I'd investigate the half volume issue - it should work just fine using the Aux input.
I used to run a 160GB iPod with a line level output with no problem.
Post #413493 14th Nov 2016 12:25pm
usb sockets didnt come in till the 2010my [tft screen]
if you have rse then there will be an aux socket you can plug an aftermarket gadget in that will stream music...
http://www.fullfatrr.com/forum/topic24633.html
the only other thing i have seen is a box that will replace the cd player and will give you an usb socket.
a member has done this upgrade here but i cant find the thread at the moment.. ... - .- -.
Post #413495 14th Nov 2016 12:29pm
miggit
If I'm not mistaken you don't have to loose the CD player when you use the LR aux adaptor, but they are like Rocking Horse Poo Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #413497 14th Nov 2016 12:34pm
Stew 46
Thanks for all info Thumbs Up 07 VSE
Post #413498 14th Nov 2016 12:35pm
miggit
Whistle Quick, this is the best way of connecting an ipod and the like... and they are really rare... I don't think they make them anymore Shocked
http://www.fullfatrr.com/forum/topic40270.html Yesterday I couldn't spell Engineer... Today I are one!
Post #413499 14th Nov 2016 12:39pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
https://www.amazon.co.uk/gp/product/B00L4Y...&psc=1
This gadget is definitely worth a look. Turns on with ignition (powered by usb) connects to iPhone automatically. All you have to do is hit play on the iphone and voila, bluetooth music! It does plug into the AUX though so if there is an issue with your AUX input this wouldnt circumvent this. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #413504 14th Nov 2016 1:17pm
Stew 46
Just ordered one , will give it a try Thumbs Up 07 VSE
Post #413508 14th Nov 2016 1:53pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
This is a bit more pounds but seems to give full integration for use with touch screen and steering wheel controls
http://umno-tech.com/catalog/index.php?cPa...af937b229e 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #413521 14th Nov 2016 3:11pm
