![]() | Home > Maintenance & Mods (L322) > Thinking Deployable steps on MY02 |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
What triggers the steps to go back in when the door is closed??? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
The motors are easy, its the movement limits that could be your problem, instead of limit switches the control module will probably have inbuilt load sensing and cut power.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2250 ![]() ![]() ![]() |
I was thinking I could use I timer relay to stop them and start them possibly? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8108 ![]() ![]() ![]() |
Why would it be a 3 wire system ?
Hmm I know this is bad as its massively off topic but I see you are in Peterborough - what boat do you have and are the trim tabs any good? I have a 19ft bowrider inboard which struggles to plane with a full load I have got hydrofoils on the drive but wondered If trim tabs were any better?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
Dan, if it helps , i've put the 2010-2012 deployable step install guide in the wiki.. ... - .- -.
![]() I've had tabs on a couple of boats & they seem to work very well - for getting on the plane & also for reducing porpoising (or bouncing around in choppy water) I used to boat in the UK, but mine lives in Bordeaux these days - Mastercraft X30 ![]()
Excellent chers - nice car nice boat! |
Enigma Member Since: 30 Sep 2016 Location: Nottinghamshire Posts: 1 ![]() ![]() ![]() |
I have put smart tabs sx on mine work very well on 19ft maxum self adjusting fit and forget... |
Nice - I will have to give them a go I think -
These any good?
Thanks - may I ask why you've got it opened up?
I did it the other day and was going to reply to you but totally forgot, the casing just has 2 tabs, pop them off and a door opens up and the board slides out.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8795 ![]() ![]() ![]() |
If the motors have five wires I imagine they will have a hall effect sensor inside to feed info back to the ECU as to their position, makes it very difficult to hot wire them and get them to work right, you need someone to make an ECU to work with the earlier canbus or I think you will burn out the motors... Pete
