|  | Home > Maintenance & Mods (L322) > Thinking Deployable steps on MY02 |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3888      | What triggers the steps to go back in when the door is closed??? | ||
|  17th Nov 2016 11:02am |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367    | The motors are easy, its the movement limits that could be your problem, instead of limit switches the control module will probably have inbuilt load sensing and cut power.
|  17th Nov 2016 11:19am |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310      | I was thinking I could use I timer relay to stop them and start them possibly? | ||
|  17th Nov 2016 11:23am |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136      | Why would it be a 3 wire system ?
|  17th Nov 2016 11:32am |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310      | Hmm I know this is bad as its massively off topic but I see you are in Peterborough - what boat do you have and are the trim tabs any good? I have a 19ft bowrider inboard which struggles to plane with a full load I have got hydrofoils on the drive but wondered If trim tabs were any better?
|  17th Nov 2016 12:19pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | Dan, if it helps , i've put the 2010-2012 deployable step install guide in the wiki.. ... - .- -.
|  17th Nov 2016 12:23pm |
  I guess you can hijack your own thread. I've had tabs on a couple of boats & they seem to work very well - for getting on the plane & also for reducing porpoising (or bouncing around in choppy water) I used to boat in the UK, but mine lives in Bordeaux these days - Mastercraft X30
|  17th Nov 2016 12:48pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310      | Excellent chers - nice car nice boat! | ||
|  17th Nov 2016 1:14pm |
| Enigma Member Since: 29 Sep 2016 Location: Nottinghamshire Posts: 1      | I have put smart tabs sx on mine work very well on 19ft maxum self adjusting fit and forget... | ||
|  17th Nov 2016 4:42pm |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310      | Nice - I will have to give them a go I think -
|  1st Dec 2016 9:42am |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367    | These any good?
|  1st Dec 2016 10:18am |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2310      | Thanks - may I ask why you've got it opened up?
|  1st Dec 2016 10:20am |
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367    | I did it the other day and was going to reply to you but totally forgot, the casing just has 2 tabs, pop them off and a door opens up and the board slides out.
|  1st Dec 2016 10:32am |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | If the motors have five wires I imagine they will have a hall effect sensor inside to feed info back to the ECU as to their position, makes it very difficult to hot wire them and get them to work right, you need someone to make an ECU to work with the earlier canbus or I think you will burn out the motors... Pete
|  1st Dec 2016 11:27am |
| Posting Rules
 except thats how the trim tabs on my boat work......
