Home > Technical (L322) > HDC Inactive message
6029 king Stephen
United Kingdom 2008 Range Rover Vogue SE TDV8 Rimini Red
Hi,
Sometimes when I start my FFRR 2003 petrol vogue, I get a displayed message that HDC is Inactive accompanied by a chime. I hadn't really worried about this as I have never really had much need to use the hill descent control but today whilst going off road I came across a deep section filled with water and wanted to raise the suspension to the off-road setting but although the light was flashing it did not lift the vehicle. I sat in Park for about 5 minutes but the light light kept flashing. When I turned the switch to return to normal the light for that setting came on immediately. I had the front air suspension replaced in January and know what the leaking hiss sounds like - i don't have any leaks at the moment. When I set the switch to access mode the car lowers and it managed to lift itself back to normal height after several minutes. On the drive down yesterday the suspension was changing from normal setting to motorway as normal.
I don't have an IID tool at the moment so cannot check for faults but do you reckon I might need to get a compressor seal repair kit off eBay?
Regards,
Steve
Post #414364 19th Nov 2016 1:34pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
Mine showed this message and was a result of low voltage in the battery; a new Genuine one sorted that out! "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #414366 19th Nov 2016 1:40pm
Weegie
They aren't related. As said by stu, the HDC is normally low battery. The slow raising etc is probably the compressor. I would try with a refurb kit from bagpipe andy and hope the compressor bores are not too badly worn.
I find that mine will rise quite quickly from access to normal but takes a little longer from normal to offroad. I put that down to the reservoir being depleted. John
GAP iiD BT-Sold
Post #414367 19th Nov 2016 1:46pm
Weegie
Double post. John
GAP iiD BT-Sold
Post #414368 19th Nov 2016 1:48pm
miggit
http://www.fullfatrr.com/forum/topic39988.html
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #414376 19th Nov 2016 3:23pm
alistairh
I've had the hdc inactive message and a host of other electrical gremlins for weeks..instaled new battery yesterday and gremlins are now deid Laughing Amazing how sensitive the fatty is to low voltages...
Post #414383 19th Nov 2016 5:46pm
miggit
Whistle Sometimes Clarkson is right, and the only thing that will do is MORE POWER!!! Yesterday I couldn't spell Engineer... Today I are one!
Post #414384 19th Nov 2016 5:57pm
alistairh
Laughing Certainly true in our beloved fattys..
Post #414396 19th Nov 2016 7:01pm
miggit
Whistle Oh dear, you really are a newbie...... Shocked
Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #414399 19th Nov 2016 7:21pm
alistairh
Laughing I'm trying...
Post #414403 19th Nov 2016 7:44pm
handyandy1966
Had same hdc inactive replaced battery still happens any ideas cheers😃
Post #414911 23rd Nov 2016 1:27pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Any other faults being reported? ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #414914 23rd Nov 2016 1:37pm
handyandy1966
No plugged in gap obd11 tool all clear
Post #414915 23rd Nov 2016 1:47pm
UK Marine
Can you update your profile to indicate what model and year your Range Rover is, it gives us a better idea of how to help you.
I would be looking first at alternator output as although you have a new battery the alternator might not be able to keep up the charge required by the car.
Regards ______________________________
Simon
Post #414917 23rd Nov 2016 2:08pm
handyandy1966
Had a had alternator checked it's a 2004_5 td6
Post #414919 23rd Nov 2016 2:14pm
