Home > Maintenance & Mods (L322) > Topix
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Topix
Am just about to subscribe for a session on Topix - can anyone confirm if the workshop manuals etc can be physically downloaded and kept or is the system a view only thing?
If downloads are possible - is a 24 hour subscription enough to get the 2011MY workshop manual? (storage space aint an issue). Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #414404 19th Nov 2016 7:50pm
hopefully there will be a download icon like this,
there are loads of sections mind so it will take a while to download..
i'll buy a copy if you'll be selling. Wink ... - .- -.
Post #414408 19th Nov 2016 8:35pm
nope they can't, Just signed up for an day. you can print the pages you want though.
if you want to be anal and download the PDF's of each procedure that is possible. Certainly on a mac. If you select print then it will open a new web page with a PDF of the procedure, which can then be saved. To do the whole WM would take a while though. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 19th Nov 2016 9:35pm. Edited 1 time in total
Post #414418 19th Nov 2016 9:27pm
you cant download then ? Shocked ... - .- -.
Post #414420 19th Nov 2016 9:33pm
see edit above. There is nothing that can't be fixed with a hammer😜😜
Post #414421 19th Nov 2016 9:36pm
also found this on the interweb,
dont even need to print it actually, when I place the mouse over the 'text' on the right, the standard PDF tool bar appears, where you can zoom in etc, but there is a 'save' icon too. Click and save straight to PDF ... - .- -.
Post #414423 19th Nov 2016 9:40pm
just been reading the instructions for the pulleys at the front end, the belt is another "fitted for life" item Rolling Eyes to get it off involves removing the viscous fan, RAVE says you need to vac the AC and drain the coolant to do this as access is limited. IIRC that it can be done without. Sometimes the WM is a bit OTT and just gives the accepted procedure, there are always shortcuts and variations.
OP is there a specific procedure you want to know about I could have a look see if its worth down loading or wether its pretty self explanatory. There is nothing that can't be fixed with a hammer😜😜
Post #414425 19th Nov 2016 9:46pm
miggit
Is there any chance of doing everyone a favour and checking the correct procedure for changing the battery... there is conflicting information as to whether a reset is needed on like for like replacement Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #414443 19th Nov 2016 10:47pm
According to The WM Step 3 of battery installation is to reset the Battery monitoring system using the diagnostics. The rest is just battery fitting standard stuff. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #414445 19th Nov 2016 10:54pm
miggit
Thumbs Up Sweet! so the first battery change will be a wee bit more expensive as you'll need to add an IID Tool to the job as well Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #414448 19th Nov 2016 10:58pm
ajac8
Thanks Gents - useful info.
The main reason for me accessing is to get the maintenance / servicing procedures but whilst I'm there I might as well download as much as I can.
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #414514 20th Nov 2016 2:10pm
Baltic Blue
I have sent you a PM.
Post #414525 20th Nov 2016 3:22pm
