Home > Maintenance & Mods (L322) > Brake failure safety issue please read
Danwilderspin
Hi all - I was driving along last week and by front brakes began to judder like they were warped , I toyed with the idea of living with it or getting new discs and pads . I like things just so so I ordered the bits from dan. Anyway whilst waiting for the discs to arrive I was driving along and had to brake fault hard and the front brakes made a horrible noise and the brake pedal went spongey and barely stopped anything... it's also was making a chuffing noise like an old steam engine. As this was now a saftey issue and I didn't want the wife or baby in it I parked it up until then it's arrived...
Then it's arrived (thanks dan) and I got going.
The original discs still had loads of meat left so was surprised and they were genuine lr parts.
I started taking it off and I saw something I'd never seen before... it had started to collapse in on itself at the vents- they rotten away. It was so bad I could press the two discs together with my thumb and index finger!
I can believe a company like lr would build a disc like this, I don't know if it's unique or not or it's not treated but this could be potentially dangerous...
So if you get brake judder take your wheels off and inspect your discs!
Post #414470 20th Nov 2016 9:38am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
have had this on a Toyota pickup that I used to tow a boat when the brakes got soaked the salt rusted em though
Post #414471 20th Nov 2016 9:43am
Mikey
Excess corrosion, caused by lack of use by the looks of things...
Post #414472 20th Nov 2016 9:45am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Wow, seen some duff brake rotors in my time.
you were lucky the inside face didn't detach!!
Looks as if the ribs have been fractured for some time, I'd be interested to see the disc broken open to see the broken faces. Was it only one or both??
Wonder if this has been caused by thermal cycling over many years, or a mismatch of the ribs during the manufacturing process, or as stated just rust. They look original/elderly. Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #414474 20th Nov 2016 9:51am
any idea how old the discs are age wise. Yes they might have a lot of meat left on them, but the level of corrosion seems quite excessive, never seen this on a disc before, even on the Mrs skoda which had 9y.o discs on it when i changed them.
there is a fair lip on the discs, but this seems an age and condition related failure rather than failure through use. Bad though. There is nothing that can't be fixed with a hammer😜😜
Post #414478 20th Nov 2016 10:32am
Danwilderspin
Well the first point is they were front so I doubt theyd really have corrosion from slipping a boat if it was the rears definately would think that's a possibility...
Secondly the cars done 145k miles and my friend was doing them with me is a bmw mechanic and he said there's no way on a BMW they'd do that many miles with that amount of meat on them but i don't know it does sound a tall order but maybe they were original?
Post #414490 20th Nov 2016 12:04pm
builder1966
lol dan in fact I had a tow bar on front as well as back on Toyota depent on weather with boat but discs went exctually the same
Post #414493 20th Nov 2016 12:21pm
Looks to me like someone has been playing at the beach, that is classic sea water corrosion, no way they are original with the wear on them...
If I were you I'd pop the sill covers off and check them, they can be very rusty under there on cars that haven't been swimming in the sea so yours need checking...
My slightly rusty ones
http://www.fullfatrr.com/forum/topic24817.html?
And poor old Mr Tee's
http://www.fullfatrr.com/forum/topic27383.html? Pete
Post #414502 20th Nov 2016 1:00pm
mickyplum
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
I'm with Haylands on that
Ive had that happen on a car before. But being a rangey its probably been doing boats into sea !
Salt water carnage Wink
Even this can happen http://jalopnik.com/these-worn-brake-rotor...1137273753 Shocked
Mick
Post #414509 20th Nov 2016 1:30pm
builder1966
you never know how a previous owner has treated a car do you?. Seen some real horrors on trailers that have been in the sea over the years I now replace all moving parts as needed on trailers now in the winter . Its about time the old Toyota boat puller got treated to new discs etc even though where done two years ago bet there no better than dans and done hardly any miles
Post #414513 20th Nov 2016 2:10pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
You woke me up Pete Thumbs Up yup they were a right old state, she's never been back on the road since I got rid of her, lavished so much money in her over the years too!
Post #414539 20th Nov 2016 5:18pm
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I had a Shogun Mk3 (2003) 3.5V6 do exactly the same thing, and they were original discs (it had 65k miles on it). As soon as I noticed the pedal pulsing, I took the wheels off at the next opportunity to see what the flip was going on. The two halves had parted in several places on both discs, but thank god not completely.
Post #414543 20th Nov 2016 6:12pm
If yours sounded so bad, I wonder what these sounded like.... Shocked Shocked
 Pete
Post #414546 20th Nov 2016 6:32pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Shocked Shocked Shocked
where we're they from pete?
Post #414551 20th Nov 2016 7:22pm
Mikey
Removed these from the back end of an RR Sport a few months back...
Post #414553 20th Nov 2016 7:31pm
