Home > Technical (L322) > Heater blower only works at one setting
Coconut
United Kingdom 2003 Range Rover HSE Td6 Barolo Black
Hi
Have just noticed that the heater blower only works at one speed.
All the lights work correctly but the fan is either on at low speed or off.
Amy ideas?
Post #415560 27th Nov 2016 1:13pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Could be the FSR at fault. My fans would run for a minute or so then turn themselves off.
There's plenty of threads about the FSR and a wiki on how to replace.....
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #415562 27th Nov 2016 1:18pm
mr_spock
I have the original one here which I replaced only to find it was ok. Happy to help you change it to try. I'm near Welwyn so quite close to you. Send me a PM if you want to try.
Post #415568 27th Nov 2016 1:52pm
mr_spock
Just to follow up - Coconut came over and I replaced his FSR with mine. It looks like the one I'd removed from mine was a replacement anyway! His original one was a little different. The heat sink rods were fewer and thicker, the casing was metal not plastic and the body was a little thicker. The replacement went in OK but was a little loose in place - still locked in with the tab but not really tight. Anyway, it worked fine.
Post #416162 1st Dec 2016 3:25pm
Coconut
Hi
Thanks to Mr Spock the fan seems to be working fine, there is a slight groan each time the fan speed is increased but that is something for another day.
Thanks Again for all of your help
Post #416209 1st Dec 2016 7:28pm
UK Marine
Happy you got sorted, well done. Thumbs Up ______________________________
Simon
Post #416211 1st Dec 2016 7:34pm
