![]() | Home > Technical (L322) > 4.2SC Noise/Droning/Reverberation |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
Speak to Powerhouse in Chesterfield. They're the company who sell the uprated pulleys for the Superchargers.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I would certainly look at rebuilding rather than replacing.
Right - need to update this.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Its not the Torque Converter is it? |
I don't think so - when I had a failing TC on a previous L322 it sent a shudder through the whole car.
I had similar and it was my alternator. It packed up in the end but no one could pin point it.
Did you get that while stationery too? This only happens with a load on the engine - a slight incline etc. |
Not quite that kind of noise - thanks though |
Know that feeling Dan. Someone once said to me that being self employed means working half days. I responded rapidly with "Yeah, pick any 12 hours ![]() Right, your noise. You say RPM related but is this in ALL gears? Using command shift would bring this one out and if it's not there in the lower gears that might suggest the 20" wheel problem which TD6's seemed to suffer with. There was a TSB about this as well but can't put my hand to it right now. If you can lay your hands on a set of 19's off a 06-09 TDV8 that would prove it. Also, if not in all gears it could be speed related perhaps? Something I had on a different car (Skoda) was the rubber flaps on the vents in the boot were stuck to the vent grilles. Once it got to 63mph I would get the booming like when you just have a back window open. Took me ages to find that one. So, under load but not free revving. Drivetrain related perhaps? Is the centre e-diff OK? I recall all S/C cars had the e-diff. Might it be stuck in the locked position? CV joints all OK? Front diff input shaft bearing? Easy to feel that one by pulling on the prop shaft and feeling for movement. Transfer box output shaft bearings? Smack bang in the middle of it all one of those would definitely cause a vibration. The only other thing I can think of is the torque converter, and you could prove that by command shift into higher gears and forcing the lock up. Tends to be more evident when pulling away from standstill. Perhaps you could find a place with a rolling road. Set the car up to reproduce the fault and stethoscope various parts until you find the vibration source. Just a thought. Good luck with it. Dom. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
don't think you can put a FF onto a rolling road Dom.... ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
There are four wheel drive rolling roads Stan, a bit few and far between though...
Thanks Haylands, some meaty questions to answer:
I only asked the last question, Dom asked the others...
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
Hi Dan,
