Home > Wheels & Tyres > Will smaller 18's fit over the Supercharged discs?
dan_uk_1984
Trying to eliminate this drone/noise I'm getting and according to this TSB there can be an issue with the 20" Alloys.
If 18"s will fit, I'll just buy a set to eliminate this as a cause - does anyone know if the 18" alloys will fit over the stock Brembo brakes as fitted to the Supercharged RR?
Thanks.
Post #416230 1st Dec 2016 9:51pm
Not the standard 18's apparently... Pete
Post #416234 1st Dec 2016 10:12pm
19" or Compomotive 18" only Sad 2008 MY Supercharged
Post #416254 2nd Dec 2016 1:40am
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
Even if they did fit you may have an issue with your insurance??? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #416327 2nd Dec 2016 5:30pm
sako243
Compmotive ones should fit, best price I've seen is going direct. I think you'll be ok on an FF but the sport has a weight / damper that needs to be adjusted in order to get it to clear. Ed
Post #416354 2nd Dec 2016 7:43pm
fisha
Stock LR 18's will not fit.
Stock 19's should fit.
As above, the only 18's that fit are the Compomotive PD1881 alloys. There is less than 10mm clearance around the caliper on them, but they are the business. Allow a lot of different tyres to be fitted. Have a wider offset as well so it sits wider and looks better. (imho)
Regarding the damper weights, these are also fitted to the FFRR in some cases (mine had them) and not just the RR sport. They are metal bars that bolt onto the inside face of the caliper with 2 small bolts. You may be lucky and the bolts undo fine. You may not (like me) and just have to hacksaw the metal that sticks out past the caliper (very easy job). V8 or else ...
Post #416386 2nd Dec 2016 11:02pm
dan_uk_1984
I'll only be fitting them to rule them out as the cause of this reverberation through the car - not a permanent change. If it turns out the noise goes away I'll fit the required Harmonic Damper.
Looks like I need to pick up a cheap set of 19's then.
http://workshop-manuals.com/landrover/rang...page_8436/
Post #416391 2nd Dec 2016 11:18pm
The suspension setting for the supercharged V8 transmits a resonant frequency from the 20 inch wheel/tire assembly to the vehicle body. This resonant frequency coincides with the natural frequency of the body cabin, resulting in the audible drone.
I wonder if lowering or raising the suspension height by a small amount might cure it... do you have an IID to have a play..?? Pete
Post #416399 3rd Dec 2016 1:17am
fisha
I still stuggle to figure out how a wheel which should be balanced can transmit vibrations enough to cause a reasonance in the cabin - or that wouldn't happen across all wheels?.
As a very simple quick check, could you try changing the tyre pressures for short test runs. For example, pumping them right up to 40+psi and then down to 25 or so and see if that makes any difference? i.e. have the tyre dampen out the vibration.
If you were anywhere near me, i'd let you try the 18's, but yer miles away ! and with a SC, I aint paying for the petrol Laughing V8 or else ...
Post #416408 3rd Dec 2016 9:59am
sako243
I think you might have to be careful over which 19" you go for as well. Post 2007 are all ok I think, the ones from before the facelift may not fit, think it's to do with the curve on the inside of the alloy.
I wait to be corrected though. Ed
Post #416423 3rd Dec 2016 11:27am
