|  | Home > Wheels & Tyres > Will smaller 18's fit over the Supercharged discs? |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014      |
 Trying to eliminate this drone/noise I'm getting and according to this TSB there can be an issue with the 20" Alloys.
|  1st Dec 2016 8:51pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | Not the standard 18's apparently... Pete
|  1st Dec 2016 9:12pm |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      | 19" or Compomotive 18" only    | ||
|  2nd Dec 2016 12:40am |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613      | Compmotive ones should fit, best price I've seen is going direct. I think you'll be ok on an FF but the sport has a weight / damper that needs to be adjusted in order to get it to clear. Ed | ||
|  2nd Dec 2016 6:43pm |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | Stock LR 18's will not fit.
|  2nd Dec 2016 10:02pm |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014      | I'll only be fitting them to rule them out as the cause of this reverberation through the car - not a permanent change. If it turns out the noise goes away I'll fit the required Harmonic Damper.
|  2nd Dec 2016 10:18pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | The suspension setting for the supercharged V8 transmits a resonant frequency from the 20 inch wheel/tire assembly to the vehicle body. This resonant frequency coincides with the natural frequency of the body cabin, resulting in the audible drone.
|  3rd Dec 2016 12:17am |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | I still stuggle to figure out how a wheel which should be balanced can transmit vibrations enough to cause a reasonance in the cabin - or that wouldn't happen across all wheels?.
|  3rd Dec 2016 8:59am |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613      | I think you might have to be careful over which 19" you go for as well. Post 2007 are all ok I think, the ones from before the facelift may not fit, think it's to do with the curve on the inside of the alloy.
|  3rd Dec 2016 10:27am |
| Posting Rules
