Home > Technical (L322) > oily diff
alistairh
oily diff
Hi folks..pottering about cleaning up the underside of my fatty and noticed the front diffs a bit oily..don't know if its a seal going but there's not a great evidence of it on my driveway (lower engine covers removed)
I've had issues since I got the car as in when I select drive or reverse the car clunks/thuds and its not very smooth...if I gently select d or r its not as bad for some reason..? Don't know if its linked but thought it worthwhile highlighting it..car drives beautiful,no whine? Thanks
Post #416474 3rd Dec 2016 6:44pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Remember Range Rovers don't leak, they just mark their territory Very Happy ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #416475 3rd Dec 2016 6:59pm
alistairh
Laughing Brilliant!
Post #416478 3rd Dec 2016 7:16pm
UK Marine
Simon
Post #416487 3rd Dec 2016 7:42pm
Check the breather's aren't blocked
Post #416504 3rd Dec 2016 9:13pm
Clivefog
Is it dry higher up?
Post #416509 3rd Dec 2016 9:25pm
alistairh
Just been out with a torch and visibility's better...bit oily above it as well..looks dirty above it and oil on diff looks cleaner?
Post #416510 3rd Dec 2016 9:31pm
alistairh
Managed to get car up on ramps today..looks like oils coming from higher up...signs of an old leak on the rocker covers...zero oil ever on my drive but underside of cars quite messy...
Post #416595 4th Dec 2016 5:44pm
Clivefog
Well good and bad news. Good it does not look like a diff leak. Bad it could be from the upper engine as you have hinted.
Only one way to be sure it is only a minor v major leak is to tear down until you find it.
Hope it is just a replaceable gasket or hose that is leaking and can be resolved easy and quickly, fingers crossed.
Keep an eye on the oil level.
Post #416598 4th Dec 2016 5:53pm
alistairh
Everything's crossed Laughing ..oil levels don't drop dramatically tbh..not a drop in the ground in over 6 months of ownership..looks like its been happening for a while..first time I've been under the car and I was shocked at the mess...last owner never cared about the fatty by the look of it...im determined to get her mechanically perfect...I'm a big fan of the cars and it makes me smile everyday...even with its niggles Banging Head
Post #416604 4th Dec 2016 6:08pm
UK Marine
The mess under the car could be the small 4" pipe from the oil separator. Mine was like chewing gum and had a small split in it. This was leading to the oily gunge coating everything underneath, but strangely like you, not a drop on the drive...
Regards ______________________________
Simon
Post #416607 4th Dec 2016 6:22pm
alistairh
Fingers crossed its that as its getting done next weekend ... Thumbs Up After that I will contact Duckworth's and source rocker gaskets as there's signs of an old leak on both sides..ta
Post #416610 4th Dec 2016 6:30pm
UK Marine
Good luck my friend. I'm going to do the air sus compressor next weekend, I've noticed it's a bit slow getting up to off-road height. It's not noisy or anything so looking at it as a bit of preventative maintenance.... ______________________________
Simon
Post #416612 4th Dec 2016 6:37pm
alistairh
Thanks...i quite enjoyed stripping the compressor down myself..my piston chamber was too badly scored and it didn't help me..hopefully you have better luck my good man Thumbs Up
Post #416613 4th Dec 2016 6:41pm
UK Marine
Mm fingers crossed Thumbs Up ______________________________
Simon
Post #416614 4th Dec 2016 6:45pm
