![]() | Home > Technical (L322) > oily diff |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 834 ![]() ![]() ![]() |
Remember Range Rovers don't leak, they just mark their territory |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Check the breather's aren't blocked |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Is it dry higher up? |
Just been out with a torch and visibility's better...bit oily above it as well..looks dirty above it and oil on diff looks cleaner? |
Managed to get car up on ramps today..looks like oils coming from higher up...signs of an old leak on the rocker covers...zero oil ever on my drive but underside of cars quite messy...
Well good and bad news. Good it does not look like a diff leak. Bad it could be from the upper engine as you have hinted.
Everything's crossed |
The mess under the car could be the small 4" pipe from the oil separator. Mine was like chewing gum and had a small split in it. This was leading to the oily gunge coating everything underneath, but strangely like you, not a drop on the drive...
Fingers crossed its that as its getting done next weekend ... |
Good luck my friend. I'm going to do the air sus compressor next weekend, I've noticed it's a bit slow getting up to off-road height. It's not noisy or anything so looking at it as a bit of preventative maintenance.... ______________________________
Thanks...i quite enjoyed stripping the compressor down myself..my piston chamber was too badly scored and it didn't help me..hopefully you have better luck my good man |
Mm fingers crossed |
