![]() | Home > Technical (L322) > DREADED FBH |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
It will read and clear faults for other vehicles. It is the CCF which is VIN locked. Mine is a MY2005 which, according to his avatar, is the same as Bob's. John
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
ah ok, well i will hopefully get to try one shortly, i have just looked at the pdf but it is not really a how to remove one, but i will just have a go getting the liner out first and take it from there.
We "doubled", Bob. John
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 124 ![]() ![]() ![]() |
Just out of interest have you checked your battery voltage while you are trying to light the burner as it will shut itself off if it drops to 11.5V IIRC 2011 4.4 TDV8 Vogue SE
actually no i haven't but i will put a test on it and check, but i have also tried to run it with the engine running so i imagine its not that, as the battery would be under charge from the alternator which would be higher than that one would imagine but i will check; but anyway, i will trying the tool in the next few days so will be interesting in what that shows up
