Home > Technical (L322) > DREADED FBH
TomCobbly
Hi Bob,
I think the GAP tool can read and clear fault codes for any VIN it is just the advanced stuff which is VIN locked. I'm also not sure if it will do the diagnostic on vehicles before MY2010. See extract from GAP manual.
4.7.5 Fuel Burning/Auxiliary Heater (L322-10, L319, L320)
Fuel Priming
This routine will remove air from the system (if present) replacing it with fuel.
Check Operation
This routine will activate the fuel burning/auxiliary heater regardless of the ambient and engine temperatures.
This routine will begin by clearing faults stored in the ECU. If the routine fails, proceed with
a read fault and fix the issue.
Hope this helps 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #416878 6th Dec 2016 4:00pm
Weegie
It will read and clear faults for other vehicles. It is the CCF which is VIN locked. Mine is a MY2005 which, according to his avatar, is the same as Bob's. John
GAP iiD BT-Sold
Post #416880 6th Dec 2016 4:15pm
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
ah ok, well i will hopefully get to try one shortly, i have just looked at the pdf but it is not really a how to remove one, but i will just have a go getting the liner out first and take it from there.
Whistle bob
Post #416881 6th Dec 2016 4:15pm
Weegie
We "doubled", Bob. John
GAP iiD BT-Sold
Post #416882 6th Dec 2016 4:17pm
TomCobbly
Just out of interest have you checked your battery voltage while you are trying to light the burner as it will shut itself off if it drops to 11.5V IIRC 2011 4.4 TDV8 Vogue SE
Post #416893 6th Dec 2016 5:12pm
BOBCUSSEN
actually no i haven't but i will put a test on it and check, but i have also tried to run it with the engine running so i imagine its not that, as the battery would be under charge from the alternator which would be higher than that one would imagine but i will check; but anyway, i will trying the tool in the next few days so will be interesting in what that shows up
Wink hopefully
bob
Post #416904 6th Dec 2016 6:10pm
