![]() | Home > Technical (L322) > Suspension inactive problems |
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 ![]() ![]() ![]() |
Hello
Not the answer I was hoping for, though it is the one I was expecting.
Forgot to say, still at normal ride hight. Got enemies? Good, you have stood up for something in your life.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
You will be fine to use rangey then.gap do the iid tool..links are in the forum somewhere...its about £400 for the Bluetooth version...i bought an icarsoft i930 for mine for about £90 brandnew from diagnostic world...quite good data reader and clears and reads eas faults but after a while I realised it was lacking and now looking to get the iid tool... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8731 ![]() ![]() ![]() |
Dan at Duckworths, site sponsor, sells the IID at a good price, well worth the extra for the BT version... |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
+1 Dan @ Duckworths.
Well I have now had it reset, however the temp sensor fault on the air compressor is still there, can these be bought separately to the pump? Got enemies? Good, you have stood up for something in your life.
Not having much luck sourcing a new temp sensor. Does anyone know how the ECU finds faults, is it a 'normally on' supply that is broken when overheating, or a normally off, or none of the above? Got enemies? Good, you have stood up for something in your life.
https://m.alibaba.com/product/1654050157/w...ensor.html
No luck so far with parts, now is not displaying any suspension function lights, so I believe in 'hard fault' mode. Strange thing is that I have now done over 1000 miles and it has not sunk at all, can the bags hold air that long? Got enemies? Good, you have stood up for something in your life.
