Home > Maintenance & Mods (L322) > Range Rover L322 Front Left Lower Wing Trim Panel
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
Hi everyone... this is my first post on here,
Ive just bought my self a range rover and the panel just below the side vent has been hanging off, after a bit of investigation I've found a few plastic tabs were broken off and the top securing bolt hadn't caught on the top of the panel, the mud flap was getting in the way of me doing it back up, I sheared both bolts removing the mudguard from the panel as they had rusted together, I also found there were 3 screws right in the back edge of the mudflap, they look like they have just been put there by someone to secure the flap a bit better and I can't see it being possible to put them back in after the panel is fitted, does anyone have any experience with this? also does anyone know where I can look up part numbers for any of these parts to find spares?
Thanks in advance!
Post #417896 14th Dec 2016 3:49pm
this thread shows how to replace the side vents and will show you how its all setup,
http://www.fullfatrr.com/forum/topic1069.html [from our wiki] ... - .- -.
Post #417898 14th Dec 2016 3:53pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Firstly, if you do a search on Range Rover L322 lower wing -mirror on a certain auction site, they are often for sale at about £35-40 with a mudflap attached in the correct colour. New ones (primed, not painted) are usually over £50 and come with all the 'pins' in place.
There are fitting instructions on "WIKI" for mudflap........no use telling you what I did because I have a different version flap i.e. for retractable side steps.
Post #417899 14th Dec 2016 3:54pm
Ollie7195
Thanks for the quick response stan! looks like someone put extra screws in mine, any idea on part numbers or will I have to go into landrover to find them?
thanks again
Post #417902 14th Dec 2016 4:02pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
Ollie ebay lower wing will bring em up bud !
Post #417909 14th Dec 2016 6:08pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
I think the part number for the clips is DYC000091 Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #417919 14th Dec 2016 6:58pm
Ollie7195
Thanks for all the replies, had a go at fixing some bits on it last night so hopefully it will work today, looks like the previous owner had hit it on something and decided to put the screws inn Neutral if not ill get another one off ebay
Post #417979 15th Dec 2016 10:19am
Top tip
www.lrparts.ru
Click in English
Click land rover microcat.
Full parts catalogue. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #418054 15th Dec 2016 7:17pm
rar110
The numbers don't look like part numbers. ______________________________
Post #418114 16th Dec 2016 10:46am
Post #418118 16th Dec 2016 11:18am
nicksaab
If you click on the blue numbers in the pictures then a pop up at the bottom of the screen comes up with the Land Rover part number Current Fleet:-
Post #418128 16th Dec 2016 12:52pm
