|  | Home > Technical (L322) > Replaceing compressor piston seal in my Rangie |
| Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011      | I recently did my piston. All went well with no error messages/lights on dash after plug back in.
|  17th Dec 2016 3:57pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825      | Make sure you get the right one, with a 2006 I think you are on the cusp of the early and late pump... It's a Land Rover, they put in whatever they had lying around.....  | ||
|  17th Dec 2016 4:14pm |
| philTD Member Since: 17 Dec 2016 Location: stalybridge Posts: 6      | Cheers for the info guys. Thanks | ||
|  17th Dec 2016 8:16pm |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267      | When I did mine it didn't work and had no light on the control on the dash,got my mate to plug it in and he had it running in minutes .You may need the same reset. | ||
|  17th Dec 2016 10:33pm |
| Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509      | I replaced the entire pump on mine as I found one for about £250 and as the kit was around £90 at the time and as I was planning to keep the vehicle for a few years I took the decision to replace the whole thing rather than the seals as I wasn't completely confident that the seals would do the job properly.
|  18th Dec 2016 3:51am |
| Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134      | Not sure that I would term the compressor a major weakness. On 'normal' cars the springs break and the shock absorbers fail. On ours the air suspension leaks and the compressors fail...service items in both cases...but I know which are the more comfortable! | ||
|  18th Dec 2016 9:19am |
|  18th Dec 2016 9:23am |
| Posting Rules
