Home > Technical (L322) > Replaceing compressor piston seal in my Rangie
philTD
United Kingdom 2006 Range Rover HSE Td6 Bonatti Grey
Hi,
New to range rovers but not land rovers lol, I am wanting to replace the piston seal in the air compressor (a bit noisy) The thing is not being used to electronics on my other Landys, Am I going to get fault codes up after replacement as there are (none now!) as I say its just a bit noisy so does anyone know if I will get any by replacing the piston seal?
If so how would I switch them off?
Post #418292 17th Dec 2016 4:28pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I recently did my piston. All went well with no error messages/lights on dash after plug back in.
I did make sure I didn't turn the ignition on whilst doing it just in case that would cause errors.
My car is a 2002 TD6.
Look at your drier granules whilst you're taking the pump apart. They may need reviving/drying out.
If not to bad you can dry them out in the oven, if like mine which were well past saving you can buy the granules (About £20).
Post #418296 17th Dec 2016 4:57pm
Make sure you get the right one, with a 2006 I think you are on the cusp of the early and late pump... It's a Land Rover, they put in whatever they had lying around..... Rolling Eyes Rolling Eyes Pete
Post #418302 17th Dec 2016 5:14pm
philTD
Cheers for the info guys. Thanks
Post #418350 17th Dec 2016 9:16pm
Rangeyman
When I did mine it didn't work and had no light on the control on the dash,got my mate to plug it in and he had it running in minutes .You may need the same reset.
Post #418372 17th Dec 2016 11:33pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
I replaced the entire pump on mine as I found one for about £250 and as the kit was around £90 at the time and as I was planning to keep the vehicle for a few years I took the decision to replace the whole thing rather than the seals as I wasn't completely confident that the seals would do the job properly.
Even after the new pump was fitted the suspension groaned and moaned when I put the car to access mode but that could have been the age of the car I.e. Other components causing the noises rather than the pump.
The car went in for its service after I had fitted the pump, which was extremely easy by the way and the main stealer cleared the fault code and it never caused any further issues.
I've heard of people converting the suspension to coil springs, although why anyone would do that is beyond me as the car was designed the way it is for a reason, although it's frustrating that this is a major weakness and all of them eventually fail. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #418390 18th Dec 2016 4:51am
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Not sure that I would term the compressor a major weakness. On 'normal' cars the springs break and the shock absorbers fail. On ours the air suspension leaks and the compressors fail...service items in both cases...but I know which are the more comfortable!
Post #418408 18th Dec 2016 10:19am
Rich86
Thumbs Up 2009 Vogue TDV8 Nara Bronze
Post #418410 18th Dec 2016 10:23am
