Home > Technical (L322) > Normal Height only then red triangle/ Don't exceed 30mph?
pld118
Hi, last couple of days, normal height only has been displaying on the dash and the car won't let us change the height settings.
Does anyone know what this indicates please?
Thanks.
Post #417330 10th Dec 2016 10:48am
Indicates you've hit something ... Whistle ====================================
Post #417335 10th Dec 2016 11:04am
Have you got a fault code off it Ryan?
Could be a faulty height sensor, failing pump, sticky valve gear. Or it could just be voltage related. Try a battery reset first, see if that helps.
I doubt it is an airbag gone, when that happened to me I had "suspension fault" show up not normal height only. I would get the faults cleared, and see what else bongs up. There is nothing that can't be fixed with a hammer😜😜
Post #417341 10th Dec 2016 11:18am
CS
Or maybe problem in towing electrics making the car think a trailer is attached? Only Range Rovers since 1988
Post #417360 10th Dec 2016 1:28pm
miggit
Do the later cars have the height lock function? ie have you pressed the centre of the button and locked the system? Yesterday I couldn't spell Engineer... Today I are one!
Post #417384 10th Dec 2016 3:48pm
pld118
Thanks all. Will check
Post #417399 10th Dec 2016 5:14pm
pld118
Hi, this issue has progressed. Not had a chance to try your solutions yet but this afternoon the car has lowered to just above the tyre tops, it is bouncing all over the place at 25mph and a red warning triangle advises don't exceed 30mph.
Presuming this will need a recovery truck and some warranty work as opposed to resetting battery etc?
Thoughts welcome.
Thanks.
Post #418303 17th Dec 2016 5:15pm
CS
The car having lowered and wallowing about suggests compressor problem or air leaking from somewhere, it is presumably sitting on the bump stops?. I'd proceed to workshop, under own steam if realistic distance, otherwise on truck. Depressing this is happening on a 2012 car. Only Range Rovers since 1988
Post #418307 17th Dec 2016 5:54pm
Time to call LR assist.
Has anyone played with the tracking recently? I had the latest issue with my disco it dropped to the floor and max 30. Turned out to be an incorrectly calibrated steering angle sensor. A garage managed to reset the sensor with the steering at 1/4 past, the car constantly thought it was cornering!! Try the lock to lock steering angle reset. There is nothing that can't be fixed with a hammer😜😜
Post #418309 17th Dec 2016 6:04pm
pld118
Thanks for the replies.
nmj, it had 4 tyres put on a month ago and the chap said the suspension height moved when he was changing the tyres, but it reset with the normal centre console hutton when I was driving away.
What is the lock to lock steering angle reset (can I try that or do you mean a garage to try it)?
Post #418314 17th Dec 2016 6:35pm
pld118
Bow down
Post #418316 17th Dec 2016 6:38pm
don know if the lock to lock works on our later cars Ryan? Did you have any success. There is nothing that can't be fixed with a hammer😜😜
Post #418319 17th Dec 2016 6:44pm
pld118
The car does recognise the lock to lock reset attempt but nothing happening other that the warning 'suspension fault' !!
LR low loader tomorrow methinks Shocked
Post #418323 17th Dec 2016 6:57pm
"suspension fault".....i had that too on mine, but it would move up and down. Was a hole in the front bag I could hear it on up Height...
Definitely get it done via LR assist. The Dealers will then prioritise it. Thumbs Up the dropping definitely sounds steering angle calibration related to me Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #418325 17th Dec 2016 7:02pm
pld118
Cheers Mark Thumbs Up
Post #418340 17th Dec 2016 8:29pm
