![]() | Home > Technical (L322) > Would u buy a tdv8 with a changed engine? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8746 ![]() ![]() ![]() |
Personally, no, plenty out there, I'd look for an original unmolested FF....
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
Depends who did the work and how well documented it is.
Couldn't be any worse than the ones at Solihull who nail them together in the 1st place Pete. As for a car that's had an engine change, yep, I would as long as I knew who had done the engine change and where the replacement came from. Back street garage and a breakers yard engine. No way. Reputable garage and recon or crated engine. Sure. Do they last long? Some do, some don't. Having one which lasts a long time seems to depend on a good maintenance regime. Plenty of oil changes with good oil, EGR maintenance, Turbo maintenance. There's no cambelt to worry about. As long as the engine doesn't lunch on its own EGRs or turbos they seem to be fairly bulletproof. I also believe lack of use is the kiss of death. These engines like to work. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Only if it was a LR warranty replacement done at the dealer, with a new LR supplied engine. |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
It was a brandnew engine with papers.
That changes things a lot....
Nice advice!!! |
