Home > Technical (L322) > Would u buy a tdv8 with a changed engine?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Do tdv8 engines last long?
Would u buy a tdv8 that had complete engine change?
Post #418342 17th Dec 2016 8:52pm
Personally, no, plenty out there, I'd look for an original unmolested FF....
You never know what some brain dead mechanic has done to it.... Thumbs Up Pete
-Click here for Thread-
Post #418383 18th Dec 2016 12:47am
Depends who did the work and how well documented it is.
Was it replaced with a brand new engine or a used one from a write-off etc.....
Post #418401 18th Dec 2016 9:51am
mzplcg
Couldn't be any worse than the ones at Solihull who nail them together in the 1st place Pete.
As for a car that's had an engine change, yep, I would as long as I knew who had done the engine change and where the replacement came from.
Back street garage and a breakers yard engine. No way.
Reputable garage and recon or crated engine. Sure.
Do they last long? Some do, some don't. Having one which lasts a long time seems to depend on a good maintenance regime. Plenty of oil changes with good oil, EGR maintenance, Turbo maintenance. There's no cambelt to worry about. As long as the engine doesn't lunch on its own EGRs or turbos they seem to be fairly bulletproof. I also believe lack of use is the kiss of death. These engines like to work.
Post #418418 18th Dec 2016 10:38am
Only if it was a LR warranty replacement done at the dealer, with a new LR supplied engine. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #418428 18th Dec 2016 11:19am
umitbat
It was a brandnew engine with papers.
Reason to buy is that price is nice.
Post #418435 18th Dec 2016 12:13pm
That changes things a lot....
Why are you reading this...... go buy it.... Thumbs Up
Oh and to answer how long they last it depends how hard you drive them, drive them hard, use the full rev range and they will last forever, drive it like Miss Daisy and it will clog up and destroy the turbo's which the engine will eat...... Pete
Post #418439 18th Dec 2016 12:20pm
umitbat
Nice advice!!!
Post #418504 18th Dec 2016 6:18pm
