![]() | Home > Maintenance & Mods (L322) > oil change without ramps/lift |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
You can do all of those oils yourself on your back with the car on the floor, just leave a door open and it won't drop, stick an axle stand under it if you like...
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Brilliant! Going to order the extra oils today and have a swat up tonight...grudge paying for a job I could do myself...cheers Pete |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Do it like that every time, off road height and away you go .
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 ![]() ![]() ![]() |
I bought a vacuum pump last year - perfect for changing the oil in any car and most dealers use a version of this.
As above and if you want more space park one sid on the edge of a curb for some extra clearance |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
Just watch the engine sump plug, they strip at piece rate.
I shall take a bit extra care then |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
As it is only the gearbox access that requires something better that a squeezable I got the much smaller vacuum pump that transfers a litre at a time. It does do the axles and transfer box in one suck and blow which is a bonus. Sealey 1Ltr I think was £10 from the bay of e. |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Not ramps per se but I took a chainsaw to a 4x4" fence post, cut them into foot long sections with a 45 degree slope on one end. Nailed three together in parallel. Repeat 4 times.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I find that ramps really help with things. The added height and workspace makes things much easier. Si. <This is my name.
