![]() | Home > Technical (L322) > Range Rover 3.6 fault codes |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Only 2 things control the high side fuel pressure, the PRV (Pressure Regulator Valve) or a spurious reading from the Rail Pressure Sensor, giving an incorrect value As silly as it sounds, try a good dose of injector cleaner, Forte or Redex, and a dosing of 2 stroke oil. This will help lubricate the PRV, if it is indeed sticking I have seen a few TDV8s with fuel pressure issues resolved by using 2 stroke oil in with the diesel. It's almost free, you have nothing to loose |
| steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208
Do you have any idea what condition your battery is in? If by any chance it is original, it will be on its last legs by now. Is your alternator charging properly?
| MuddyLandy Member Since: 23 Dec 2016 Location: Aberdeenshire Posts: 9
Hi Mikey thanks for advise,
Hi steveball,
In my experience, it's worth checking battery and charging system carefully. Electronics likely to show faults long before any symptoms of struggling to turn the engine over. Try to see how old the battery is. They really don't last forever. Current: 2010 Range Rover L322
Thanks steveball, anything is worth a try, thanks to all so far for help, very nuch appreciated |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
Had a similar problem on a 3.6 a couple of years ago
Hi Cass,
I can't remember all of the details now as this was a few years ago but I do remember that in addition to all of the comms codes the one consistant thing was that the oil temperature always gave a stupidly low figure on the diagnostics as in minus
Should have added the rear brake caliper seized so was replaced by a local garage.
Thanks cass |
| Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577
HI MuddyLandy,
| Adi322 Member Since: 20 Oct 2022 Location: hampshire Posts: 10
Hi Grofus
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
Kind of same as above. Start with the battery then alternator, then move on to further investigations from there. Mechanics will all too gladly take your money whilst not getting to the bottom of what is frequently a simple problem.
| All times are GMT |
