![]() | Home > Technical (L322) > Removing ball joint - at wits end |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Blimey!
And talking of being waded, I present you with a hub nut |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I edited the post and added a couple of other bits, linking spanners can help.
You could always make yourself some scaffold board ramps, these were for my transmission project.
Holy crap, that is bad, that has been used to wade in salt water by the look of things, heres mine. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
Stacker, think I'd be looking at a replacement hub and drive shaft, or at least outer CV joint, doesn't look like you have much of the nut left at all....
Thanks for the pictures, I'll see if I can make something up and have another go on Sunday. I might look into getting a dremel as if I can get that in there I wouldn't need to take the brakes off at all, cut the head off the bolt then knock the |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
I really really like this idea!! I presume it's definitely safe to carry the 2.5 ton weight? lol Matt Current 2012 Range Rover 5.0L SC Ultimate Edition 2012 Range Rover 4.4L TDV8 Autobiography 2010 Range Rover 3.6L TDV8 Autobiography 2003 Range Rover 4.4L V8 Bespoke Vehicle Inventor of the retro fit paddle shift and many other modifications. Creator of the custom 2010+ RR MK4 splash screen. Creator of the Range Rover CarPC and lots more! Founder of Range Rover Owner rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos โ YouTube.com/RangeRoverOwner |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Like every job on the Ffat,it is hard work but one thing I have learned with age is spraying up before tackling a job ,either the day before or even better a few times even a week or two before,you will be amazed with the difference. |
One step closer to heaven baby!! It's out I managed to smash a socket over it!!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Bet that was a " |
Good effort, that's the spirit, these fecking cars are just a massive mind |
I was shocked but happy!!
This is how far I've got today, had to stop now for work
