![]() | Home > In Car Electronics (L322) > Number plate bulb size? |
| steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208
Yes it's a festoon bulb. 5W size 11mm x 35mm.
| HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169
Thank you for that |
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
These were recommended on here recently as an upgrade.
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
Says they are error free but also says they can cause issues in sensitive cars? Has anybody tried them yet..I've changed all interior to leds then sidelights. I'm wanting to do something with the reverse and number plate ones next |
| hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294
I thought those were the reversing light bulbs? I fitted these number plate lights, bit of a tight fit but no issues. http://www.ebay.ie/itm/141857574520?_trksi...EBIDX%3AIT |
Perfect.. how many leds where on the ones you purchased buddy? There's a couple of choices |
Off the top of my head I think I put 2 in the footwells, 2 in the numberplate lights and one in the rear right loading loading space (boot).
Sorry, I read that wrong, 6 led's on each I think, I'll check and let you know if they were different but I'm 99.9% sure they were 6. |
There are quite a lot of options for bulbs. I have recently replaced the following.
That's great! Thanks for the write up.. ordered |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
My foot well lamps are T5's (capless) not festoon, the only festoon bulbs that I have come across are the number plate lamps |
You are correct Hamlet. My apologies for leading the OP astray. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
Incorrect quote |
| All times are GMT |
