Home > Maintenance & Mods (L322) > Headlights 2010-2012
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Hi to all.Wondering whether is possible from the attached photos to tell me whether headlight is bi xenon or not.
Think that the main beam bulb type is d3s and the other bulb is normal halogen one
Thanks for your assistance
Post #420779 2nd Jan 2017 6:10pm
i can tell you without looking at pics that the headlight will be bi-xenon.. ... - .- -.
Post #420780 2nd Jan 2017 6:14pm
AKIS
Stan many thanks for your reply.Problem is that i have only main beam from hid bulb.Signal and high beam are from halogen bulb.Headlights retrofitted when i did the facelift.So can it be a wrong connection problem????
Post #420786 2nd Jan 2017 6:35pm
sounds like the shutter isn't opening for the main beam...could be stuck?. ... - .- -.
Post #420788 2nd Jan 2017 6:39pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
If you're asking for MY10-12
Mine is MY11
I have xenon for dipped beam, halogen for main.
Post #420839 2nd Jan 2017 10:06pm
to clarify, for 2010-2012, the xenons [D3S] do the dip and main beam using a shutter system, the halogen [H7] does the main and flash..
this is from the WM,
Post #420842 2nd Jan 2017 10:16pm
supershuttle
yep Stan is right I have a MY 2010 and D3S does dip and main Geoff
Post #420847 2nd Jan 2017 11:10pm
Rambles
Xenon is on for both dip and main, correct.
Halogen is on for only main.
I have not noticed my xenon beam being deflected when I switch to main. The light pattern from the xenons remains as usual, only difference is the addition of the halogen beam to the xenon beam.
Maybe my shutter system has never worked.....but that is not how I would interpret the WM. just that the xenon beam is on for both low and main beam, which it is.
Post #420858 3rd Jan 2017 12:00am
Rambles
P 225 of the MY11 handbook
Tells you MY11 has both halogen and Xenon. No mention of bi xenon in the handbook, just Xenon.
And indeed why would you need bi xenon when you have additional halogen for the main beam?
That WM extract says halogens are for vehicles with conventional headlights.
100% my MY11 does not have halogen for dipped, but it does for main. It is not consistent in that respect.
And to repeat, my Xenons are on during both dipped and main beam operation, but I have not noticed the beam pattern of the Xenons to change.
Therefore I believe my Xenons to be Xenons, as per my handbook. Not bi Xenons.
Post #420861 3rd Jan 2017 12:12am
Rambles
And just to confirm, I recently changed my xenon bulbs for osram night breakers, and the halogens for Phillips racing. They work perfectly.
AKIS.
You say you only have main beam from the HID.
HID = Xenon.
You then say you only get high beam from Halogen.
By main beam do you mean low or dipped beam?
For me main beam = high beam.
Is your issue that your Xenons turn off when you turn the halogens on?
If so, this isn't right. The Xenons should stay on for both dipped and main.
Post #420865 3rd Jan 2017 12:26am
rambles, i would cover your inner main lights with cardboard or similar and then try the main/dip on the stalk..this way you might be able to determine if yours work properly or not. ... - .- -.
Post #420878 3rd Jan 2017 8:01am
AKIS
Hi Ramples.High beam i mean the one when blue light in dash comes on.this one is halogen
and with main beam which xenon the one normally used in city (must be the low one)
While high beam on main beam remains on as well.
Stan basis that both shutters are stucked, i suppose each headlight has one, is there any way try unstuck them??
but still factory has foreseen in case of such problem high beam to be routed to halogen bulb????
Sorry but not specialist at all
Post #420932 3rd Jan 2017 1:24pm
looking at your car profile it says you have a 2004, the headlights are 2010-2012, so is yours a front end conversion ? , if so then i think the conversion wiring might be at fault...
Post #420940 3rd Jan 2017 2:00pm
AKIS
Right stan.As i mentioned above car is facelifted and i have used the attached diargram for connecting lights
Post #420943 3rd Jan 2017 2:18pm
we're on the right track then Thumbs Up
unfortunately this limits my expertise on this subject so i cant help any more except for suggesting you read this thread ,
http://www.fullfatrr.com/forum/post251640.html?#251640
or pm Matt for some advice..
Post #420949 3rd Jan 2017 2:47pm
