![]() | Home > Technical (L322) > chain guide renewal - 2004 BMW 4.4L V8 Petrol - Update |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I used Febi Bilstein chains and guides in mine which seem ok but I have another underlying issue of potential head gasket failure and also a top end rattle which I think is because the engine was overheating after a top hose blew off so I don't think any of this is related to my chains and guides
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 405 ![]() ![]() ![]() |
I'm thinking you'd need to budget for about £1200 all in, though you might get it a little cheaper by finding the right place.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
Thanks Andy, was hoping you would pop up. Just waiting for saint v8 to give his verdict now!
Do not need to take out the engine, think only some of the BMW cars require this, most garages don't like to do the job.
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
Thanks for the info HC |
No problem, are you looking to change the guides for fun or have yours broken up ? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
I'm getting a price for mine this week so shall compare.. my engines relatively quite and I love the car so if it's going to prolong its life then I'm getting it done..I shall report back on Tuesday once mechanic looks over it..any other wee jobs I should add in as he will have it in bits and I reckon it's worthwhile doing.. |
Cool, i think my head gaskets are ok, i think i had a problem with bleeding the air out after fitting the 80 degree mod, never had a problem with the standard stat.
Well this is depressing.....
I am getting a little confused as to who has got what !! |
Hi Andy,
Blimey, you have been around the houses |
Hi Andy,
187 K and LPG you would be a good candidate for guides, the timing chain wont have failed, it may be a longer than when it was born but not enough to make a noise, the timing chain tensioner is one nut, but it is not in a great place to get to without the right socket and bar and not likely to have failed to the extent of causing, and i quote "A noise like a skeleton w@nking in a biscuit tin"
