Home > General > Has anyone got an L322 V8 Certificate of Conformity?
jerrytlr
France 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi
I am in the process of re-registering my 2003 L322 V8 Petrol in the UK (it was originally registered in the UK but I exported it to France about 3 years ago).
I need some info from the CofC, but I stupidly did not take a copy of that when I gave the prefecture in France the paperwork.
Does anyone happen to have the CofC for a car with the same (BMW) engine as mine? I just need a few bits of info that are missing from the French V5 equivalent, and really want to avoid the cost and delay associated with obtaining a new CofC from Land Rover.
Info I need is:
- type
- variant
- version
- HC g/km
- NOx g/km
- Drive by sound level
- Track width for axles 1 and 2 (max and min)
I suspect none of this is really necessary as the car was originally a UK car, but I don't want my form to be bounced because some of the information is missing...
Thanks in advance to anyone that can help me
Cheers
Jerry
Post #421933 9th Jan 2017 6:13pm
A few leads here
Post #421935 9th Jan 2017 6:22pm
jerrytlr
Thanks Alistair.
I had already looked at most of those posts, I am really just hoping that someone has a copy of the CofC and can read a few numbers off it for me (or send me a scan).
Cheers
Jerry
Post #421937 9th Jan 2017 6:35pm
Weegie
I have the C of C for mine. It is a 2005 diesel but the information may be generally the same. Obviously emissions will be different.
Type: LM
Variant: AMC
Version: 013
Plus this:
http://www.lacentrale.fr/fiche-technique-v...-2003.html
Hope that might help.
PS. I believe we aren't very far from each other.
Regards John
GAP iiD BT-Sold
Post #421942 9th Jan 2017 7:10pm
jerrytlr
Thanks Weegie that is very helpful!
I am near St Yrieix la Perche if you know where that is...
Does your CofC also show the Type Approval/Category information?
Or the Track Width?
Many thanks again
Cheers
Jerry
Post #421954 9th Jan 2017 7:59pm
Weegie
Jerry,
Type: LM (as above)
Category: M1G
Front 1629mm Rear 1626 mm
I am next to Miallet, about half an hour (if that) from you to the west.
As I said, it's a diesel but, hopefully, of some help. AFAIK the dimensions etc are the same. Just the power plant is different.
ATB John
GAP iiD BT-Sold
Post #421958 9th Jan 2017 8:23pm
verydisco
I was going to scan you mine, as I did the same thing and am about to do the same thing...
anyway, I do not have a copy either it seems, as the garage took care of it all.
That said, I tried to use the law stating our L322s already have a conformity type approval. LR France confirmed, before producing a CoC anyway (french bureaucracy...) see below:
----- Mail transféré -----
De : "omolog, H" <homolog>
À : XXXXXXX XXXXXXX
Envoyé le : Mardi 20 août 2013 16h19
Objet : Re: Tr : Certificat de conformité Range Rover L322
Monsieur,
le véhicule numéro de série SALLMAMA33AXXXXXX est homologué pour l'Europe puisque la lettre K du V5 (document anglais) est renseignée par un numéro e11* (numéro d'homologation Europe).
Vous pouvez nous envoyer le dossier et le chèque à Colombes. Nous vous enverrons en retour une attestation pour la préfecture française.
Ci joint le formulaire adéquat.
Bonne réception
Cordialement
Nicolas Du Royaume
_ _________________
Service Homologation Jaguar Land Rover France S.A.S.
165, boulevard de Valmy - Z.A. Kléber
Bâtiment Ellington - 92700 COLOMBES
Immatriculée sous le n° 509 016 804 au RCS de Versailles
N° SIRET: 509 016 804 00015
N° TVA Intracommunautaire: FR 85509016804
Capital social : 3.115.880 € l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #421980 9th Jan 2017 9:19pm
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
bought a L322 TDV8 VOGUE from 2011 recently
got a copy of the certificate if you still need
Post #422300 11th Jan 2017 11:22pm
nmaccann
France 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Re: Has anyone got an L322 V8 Certificate of Conformity?
Hi Jerry
I am in Jumilhac (14km from you).
Can you PM me. I am new to the forum so cannot PM you.
I can help and am about to use or convert my 4.4 V8 to E85 use so have some questions for you.
Thanks
Niall
Unnecessary quote removed
Post #446699 5th Aug 2017 1:03pm
