![]() | Home > Technical (L322) > Problems starting the engine |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Hi all
If you are having problems starting it from cold it could be needing new glow plugs |
Thanks mate. So far it's always been when cold. Hopefully the dealer will get to the bottom of it for me. FFRR TD6 HSE
+1 for the glow plugs, even if 1 or 2 have failed then the engine can have trouble starting.
Thanks Dan, I'll give it a go this morning. FFRR TD6 HSE
Love it!!! Wont start at all today!! 5 days into owning it. I am not happy |
It was to begin with.
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
I had problems with injectors which made it a |
Just heard from garage. Low pressure fuel pump apparently. Should be getting it sorted tomorrow. FFRR TD6 HSE
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Get them to replace both, reason being when the low one begins to fail, it puts more pressure on the high pressure, so often that will fail afterwards, it happened to me on my 530d (same engine).
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
Ask them to take a picture of it and the electrical harness connected to it. Just for interests sake.
I'll ask about them doing both. However its under warranty and they may not be prepared to fix something that isnt actually broken at the moment. Worth an ask mind.
They have replace the fuel pump, but it still doesnt start!! FFRR TD6 HSE
Have they tried the fuel pump relay in the engine compartment? 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
