Home > Technical (L322) > Problems starting the engine
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Hi all
Right, 3 days after purchasing my 1st FFRR and its having issues starting. Took me about 2-3 minutes this morning of turning starter over, and then trying again and again. Did it again after being in a meetings for 4 hours. Have spoken to dealer as have 3 month warrenty and they are going to take a look tomorrow but wanted to ask if anyone has had similar problems. Could be something as simple as battery maybe???
Also, and this might be a complete coincidence but it seems to start better when I have my foot pushing on the break pedal.
Any advice would be great
Cheers FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #42216 13th Dec 2010 10:29pm
If you are having problems starting it from cold it could be needing new glow plugs
Post #42220 13th Dec 2010 10:41pm
GregP
Thanks mate. So far it's always been when cold. Hopefully the dealer will get to the bottom of it for me. FFRR TD6 HSE
Post #42247 14th Dec 2010 12:18am
dan_uk_1984
+1 for the glow plugs, even if 1 or 2 have failed then the engine can have trouble starting.
Try cycling the ignition twice before starting, this will run the glow plug timer twice.
Post #42250 14th Dec 2010 12:42am
GregP
Thanks Dan, I'll give it a go this morning. FFRR TD6 HSE
Post #42254 14th Dec 2010 8:09am
GregP
Love it!!! Wont start at all today!! 5 days into owning it. I am not happy Sad FFRR TD6 HSE
Post #42257 14th Dec 2010 9:41am
Is the engine turning over?
Can you see if there are any air bubbles in the clear fuel line that goes to the filter?
Post #42258 14th Dec 2010 10:02am
GregP
It was to begin with.
Break down have been out and sorted. He reckons fuel pump.
I am heading out the garage now to open a can of woop ass on em!! FFRR TD6 HSE
Post #42262 14th Dec 2010 10:29am
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
I had problems with injectors which made it a Censored to start ask garage to check them
Post #42266 14th Dec 2010 10:51am
GregP
Just heard from garage. Low pressure fuel pump apparently. Should be getting it sorted tomorrow. FFRR TD6 HSE
Post #42308 14th Dec 2010 6:03pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Get them to replace both, reason being when the low one begins to fail, it puts more pressure on the high pressure, so often that will fail afterwards, it happened to me on my 530d (same engine).
You should notice a great improvement in performance and economy once you have them both replaced.
Cheers,
David 2012 SDV8 Vogue SE
Post #42309 14th Dec 2010 6:37pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Ask them to take a picture of it and the electrical harness connected to it. Just for interests sake.
Mine failed a few months back because the the connector was melted and charred and was shorting. Not good considering the fuel pump sits in the tank. LR know about this issue and have been in touch with the dealership that fixed it.
It cost about £500 to put right but was only 1.5 hrs labour. The rest was parts...
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #42312 14th Dec 2010 7:05pm
GregP
I'll ask about them doing both. However its under warranty and they may not be prepared to fix something that isnt actually broken at the moment. Worth an ask mind.
I'll just be glad to have it back and working. FFRR TD6 HSE
Post #42324 14th Dec 2010 8:24pm
GregP
They have replace the fuel pump, but it still doesnt start!! FFRR TD6 HSE
Post #42470 16th Dec 2010 11:44am
stevegt
Have they tried the fuel pump relay in the engine compartment? 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #42474 16th Dec 2010 1:51pm
