Home > Technical (L322) > Judder when braking
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Judder when braking
Hi All,
So, I had a pulsing through the brake pedal when braking moderately, I felt sure this was warped discs, so ordered and fitted Britpart cross drilled and grooved discs and EBC ultimax pads, and guess what, right, no change.
Car is a 2007 TDV8 with 188k kms, what do I check next?
Post #423519 18th Jan 2017 5:46pm
n1cktdv8
Couple of years ago I had a similar issue. Mine had decent pads but I fitted LR genuine and the judder vanished.
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #423521 18th Jan 2017 5:48pm
DavidS
Hmm, Censored
Post #423525 18th Jan 2017 5:55pm
Could be pads - could be a sticky caliper, or could be flange / hub causing the disk to not rotate completely true - or could be something else entirely.....
Post #423528 18th Jan 2017 6:13pm
DavidS
I was thinking, bushes, ball joints etc but will take the discs off again to be really sure they are seated flat as a very flat thing, any other thoughts?
Post #423529 18th Jan 2017 6:21pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Brake judder at what speed or is it the same whatever speed you're braking at? 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #423540 18th Jan 2017 7:12pm
johnboyairey
did you check the rears? cant be wrong to look there, if only as prevention/rule out/safety.
Post #423545 18th Jan 2017 8:01pm
funnyguy1
United States
Sounds like rotors might be warped.
Post #423640 19th Jan 2017 3:00am
DavidS
It's not really noticeable at less than 45 mph and most noticable above 55 but only when braking gently/moderately.
Post #423656 19th Jan 2017 9:23am
DavidS
Discs are what we Brits call rotors, see post 1 Very Happy
Post #423657 19th Jan 2017 9:24am
DavidS
Good point, will check at the indie with a run-out gauge, but not hopeful as it feels like front.
Post #423659 19th Jan 2017 9:26am
miggit
Whistle I'd check the fronts are running true at the same time... I had a warped new disc... It was a Britpart drilled a slotted one Whistle
Because it was obvious which side was warped I put the old disc on just to check.. and it disappeared.. So Miffed of Milton Keynes was sent a new disc... funnily without question Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #423673 19th Jan 2017 10:03am
DavidS
Miggit, I take that on board, but, the old ones where replaced because of pulsing, so doesn't this point to something else, bearings etc?
Post #423680 19th Jan 2017 10:18am
DavidS
By the way, did you notice that the new "rotors" where much noisier than plain discs?
Post #423681 19th Jan 2017 10:21am
miggit
Err sort of Whistle only under heavy braking Rolling Eyes But it's a small price to pay for the stopping power that they offer Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #423688 19th Jan 2017 10:35am
