Home > Technical (L405) > Any L405 owners experienced front driveshaft grinding?
mzplcg
As title chaps. It's going in again tomorrow for a failed EGR valve and the deployable steps have packed up.
But, coming home tonight I was turning right out of a junction and when pulling away it hesitated which I thought was the EGR causing a lack of turbocharger effort, but then a godawful noise like a failed CV joint started on the front nearside. It stopped when I straightened up and I didn't have any more right turns on the way home to try and reproduce it. Has anyone else come across this at all?
I'm going to ask the dealer to look at it tomorrow but I am right on the verge of rejecting the car TBH, it's been nothing but bother since I got it Rolling Eyes
Post #423837 19th Jan 2017 8:37pm
JasM
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Not had any issues with the driveshaft.
Sounds like you are not having much luck with your L405. Sad
Mine is currently on 32k miles and has been pretty much fault free apart from a few small niggles & now knocking from the suspension. 2014 SDV8 Autobiography Cool
Gone: 2012 RRS SDV6 HSE, 2007 RRS TDV6 HSE
Post #423859 19th Jan 2017 10:26pm
mzplcg
Well, been considering the options and am going to a different dealer tomorrow to get a slightly more independent view of the matter. Hopefully it's fixable but if I end up rejecting I really don't know what I'll do from there. Another L405 looks doubtful based on this one.
Post #423863 19th Jan 2017 10:38pm
back to a 322 Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #423870 19th Jan 2017 11:06pm
peekay
2016 Range Rover Autobiography SDV8 Corris Grey
It's funny you mention that, thought I was going mad.
I have had mine for nearly five months but for the first two I think I had something similar. I am not technically minded so apologise.
If I was steering right up a hill ( by that I mean not full lock or sharp turn, more manoeuvring), I would get a clunking from under the car, the moment I straightened up and it stopped. My logic was it would get worse and didn't want to waste time taking it to a dealer to fix. Then it stopped! Either something has broken that I don't use/don't notice or I imagined it! Not suggesting you have imagined it but It used to be pretty repeatable and now never happens so not sure how I approach the garage with that or what the problem was.
That is probably not a lot of help, sorry !
Post #423874 19th Jan 2017 11:42pm
Sorry to hear about your further issues - Sounds like you got a lemon Sad
I wouldn't give up on the L405 though - there are plenty of happy owners on here - it might actually be the easiest way out as the dealership are more likely to do a trade than a refund.....
Post #423904 20th Jan 2017 10:14am
mzplcg
OK, well I had a moment of inspiration once I had calmed down enough to think straight. I emailed Dr Ralf Speth, the CEO of JLR globally. A very nice man who I have met personally. Without wanting to divulge too much in open forum I believe we might be heading the right way now.
Post #423919 20th Jan 2017 11:29am
AndyS
I think it's only right and fair that you divulge his email address and mobile number on this forum so that we can bombard him with praise for his products Razz
Post #423991 20th Jan 2017 5:25pm
Laughing Laughing Bow down All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #423997 20th Jan 2017 5:47pm
ralf.speth@jaguarlandrover.com Whistle
Post #423999 20th Jan 2017 5:49pm
mzplcg
For the record, ^ That wasn't me wot posted that!! Rolling with laughter
Post #424033 20th Jan 2017 9:50pm
CubaLibre
I also have exactly the same thing -happens when pulling away with the steering turned left or right with the noise disappearing when I straighten up.
What was the outcome?
Post #429598 1st Mar 2017 1:16pm
mzplcg
It's an issue with the wrong lubricant in the transfer box. Depending on how long you've had the issue it either needs a change of fluid or a replacement transfer box.
Basically the wrong oil causes the clutches to grab and bind, and ultimately destroy themselves if left unrectified.
Post #429600 1st Mar 2017 1:59pm
Rob99
So is that not a recall issue?
Or at the very least a free check at the MD and then oil change or box under warranty.
Has a TSB been issued about it? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #429601 1st Mar 2017 2:22pm
CubaLibre
Unnecessary quote removed
Many thanks - your info is much appreciated. I'll be onto my dealer tomorrow to have it looked at along with my misted up headlights.
Post #429646 1st Mar 2017 10:37pm
