![]() | Home > Technical (L322) > buzzing, resonance,vibration |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
i couldnt find the 'live values' for the injectors , do you know where i can look paul.. |
| proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452
i also looked but could not find them for the 4.4, but certain that they were there for the 3.6 Regards
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
I'm with miggit, if you turn that tickover trace upside down it looks a bit like this......
so what makes you think its the injectors then? |
i've spoken to Pat and he says it is possible to get the live injector values for a tdv8 4.4 with the iidtool , so i'll have a look over the weekend and report back.... |
Sorry Stan, just said that for the effect... I'm no good with diesels... sounds plausible but who knows... the dealers should have access to a mobile master tech who should be able to sort it, ask them to get some help if they can't fix it... |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
This does not account for why Stan says car was good before work to do turbo drain and fix steps, but noisy/ vibrating when he got car back ???? G reg 2.5VM Vogue Portofino red 1991- 1999
I don't know what's involved with that drain fix, if the engine has been apart then it is unheard of some dirt getting dislodged and is now causing a restriction in the fuel line.... it could be a bad electrical connection... I've never heard of that in the same phrase as Range Rover |
that's a lot of sense there Paul, thank you..
Stan, If you could sahre the info about the IIDTool, then it'll be good for future reference |
no probs Mark,
| All times are GMT |
