Home > Maintenance & Mods (L322) > Clapping noise from front brakes
Danwilderspin
Hi all - when I have the window open and brake and low speed when I first press the pedal inhearligh like a metallic claps just once and the brake work fine. Everything seems type but it happens everytime - any ideas?
Post #424049 20th Jan 2017 10:48pm
miggit
Whistle Have you got discs like this.....
or like this......
If they are like the top it could be worth taking them off and checking for cracks, and if they are like the bottom.. it's the price you pay to stop better Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #424059 20th Jan 2017 11:21pm
Danwilderspin
Hi might - brand new genuine rr discs from Dan at duckworths 2 months ago - shouldn't be cracked should they?
Post #424162 21st Jan 2017 8:56pm
Could be the pads moving in the calliper, or if the calliper sliders are worn then them moving a bit and letting the calliper move against its carrier.
If the discs are new genuine then they should be ok, the only way you are going to find out is to strip them down. There is nothing that can't be fixed with a hammer😜😜
Post #424167 21st Jan 2017 9:28pm
I would check to see if all the calliper bolts are tight. Thumbs Up
Post #424211 22nd Jan 2017 11:01am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Or the carrier bracket that the calliper is attached to... two big bolts at the back of the brake assembly. They would have to have been removed to replace the discs and might not be fully torqued up 👍 Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #424244 22nd Jan 2017 1:41pm
