![]() | Home > Maintenance & Mods (L322) > Clapping noise from front brakes |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2300
Hi might - brand new genuine rr discs from Dan at duckworths 2 months ago - shouldn't be cracked should they? |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Could be the pads moving in the calliper, or if the calliper sliders are worn then them moving a bit and letting the calliper move against its carrier.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
I would check to see if all the calliper bolts are tight. |
| StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129
Or the carrier bracket that the calliper is attached to... two big bolts at the back of the brake assembly. They would have to have been removed to replace the discs and might not be fully torqued up 👍 Current: Supercharged 06 FFRR in Java Black
| All times are GMT |
