![]() | Home > In Car Electronics (L322) > Battery drain issue after fitting tracker |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1465 ![]() ![]() |
Fitted tracker recently which works great.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35674 ![]() ![]() |
would the tracker somehow be keeping the westie awake.... |
Hadn't thought of that. How can I tell?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8570 ![]() ![]() ![]() |
Just try running a wire direct to the battery, could even go outside to get it there for now, see how that works... |
Thanks Pete |
Yes to both mate... |
Wired tracker directly to main cable in rear fuse box yesterday. Got in this afternoon after parked on the drive for 24hrs and everything was fine and dandy, no different from any other day, and it turned over and started without any issues. |
Well done Rob... |
Rob, the big red wire in the boot comes to the back via a 100amp fuse at the front, fuses are used to protect the wiring, nothing runs off it until it is split up in the rear fuse box, just to let you know... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks Pete |
Um.. Err.... No.... Pete
