Home > In Car Electronics (L322) > Battery drain issue after fitting tracker
Rob99
Fitted tracker recently which works great.
On the first day I connected it about 2pm but when I went to start the Westie next morning at 8am, although everything lit up with the ignition, it just wouldn't turn the engine over. It wasn't completely drained but presumably enough for the car not to turn over. A quick jump from a spare battery and it was fine after a short run so can't have been that bad.
Having asked Pete (Haylands) if he had the same problem he said his have sat for weeks and not drained the battery. Confused
I need it wired in to a permanent live and it is drawing about 130mA current which I wouldn't have thought would have drained such a huge battery hardly at all, let alone in the space of 18hours. Shocked
Any thoughts? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #424743 25th Jan 2017 2:13pm
would the tracker somehow be keeping the westie awake....
Post #424748 25th Jan 2017 2:41pm
Rob99
Hadn't thought of that. How can I tell?
Will it make a difference which fuse i have piggy backed off. I used one of the trailer fuses as I don't have a towbar or trailer electrics? 2021 D350 Fifty Edition - Carpathian Grey
Post #424750 25th Jan 2017 2:45pm
Just try running a wire direct to the battery, could even go outside to get it there for now, see how that works... Thumbs Up Pete
-Click here for Thread-
Post #424763 25th Jan 2017 4:12pm
Rob99
Thanks Pete Thumbs Up
Would wiring it direct to the big red cable that comes into the rear fuse box be the same, as I assume this comes direct from the battery?
Does 130mA sound about right for current? 2021 D350 Fifty Edition - Carpathian Grey
Post #424765 25th Jan 2017 4:17pm
Yes to both mate... Thumbs Up Pete
Post #424767 25th Jan 2017 4:20pm
Rob99
Update.....
Wired tracker directly to main cable in rear fuse box yesterday. Got in this afternoon after parked on the drive for 24hrs and everything was fine and dandy, no different from any other day, and it turned over and started without any issues. Thumbs Up
So, as suggested, piggy backing off another fuse may have confused my Westie into thinking it had to stay "awake" for something. Hopefully all will be fine from now on although I do have a fully charged battery on standby for the morning if it all goes horribly wrong tonight. Fingers crossed. Whistle
Next job, dashcams...... Rolling Eyes
Thanks guys Bow down 2021 D350 Fifty Edition - Carpathian Grey
Post #425412 29th Jan 2017 3:55pm
Well done Rob... Thumbs Up Thumbs Up Pete
Post #425466 29th Jan 2017 8:09pm
Rob, the big red wire in the boot comes to the back via a 100amp fuse at the front, fuses are used to protect the wiring, nothing runs off it until it is split up in the rear fuse box, just to let you know... Thumbs Up Pete
Post #425469 29th Jan 2017 8:15pm
Rob99
I have an inline fuse in the live feed so all ok at the moment.
Missing your fatty much?? 2021 D350 Fifty Edition - Carpathian Grey
Post #425499 29th Jan 2017 9:26pm
Um.. Err.... No.... Pete
Post #425523 29th Jan 2017 11:53pm
