![]() | Home > Technical (L322) > chain guide renewal - 2004 BMW 4.4L V8 Petrol - Update |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Good job, that should see you ok for a while !!
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 405 ![]() ![]() ![]() |
How on earth did they get 17 litres of fully synthetic oil into it? I guess it could be done by leaving the drain plug out. Current:
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i think he mentioned, that they filled/filtered it, ran it, emptied it, and repeated, hence 2 fills of oil. (x2 filters) |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3267 ![]() ![]() ![]() |
Hi John boy, no they wanted another 3-4 hrs + £90 for the valley so I reckon it wasn't a problem before so prob best leave it.
Might be fuel pressure related as the fuel line at the rear right as you are looking is a quick connector and would have been disconnected. You can test the fuel pressure is not draining back by releasing the schrader valve on the fuel rail when the engine is cold EDIT AND ENGINE SWITCHED OFF and making sure you cover it with a rag first and you should get a definite squirt and pressure release. It is just a tyre valve so press something into the hole after removing the dust cap.
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341 ![]() ![]() ![]() |
Hey @holidaychicken, super useful you listed all of the parts which is super amazing!!! - I've seen this kit, any advice on it please??
