![]() | Home > Technical (L322) > Engine valve noise and high consumption. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
What vehicle and engine , I can't see it anywhere ?
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Sorry.06 td6 160k km.
I don't know much about the TD6 I'm afraid but others on here should be able to help out |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
Fuel, Oil or water consumption...???
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
My TD6 got harder to start when it was hot, it didn't want to go one bit, turned out that I had some blocked injectors. I had all of them cleaned by a Bosch Service Centre and 2 were rebuilt with new needles and tips. after this had been done the car was back to normal again starting with a flick of the key |
God thanks i dont have 22 lt oil consumption!!!::)Only diesel!!! Power is fine i rebuilt the intank pump it was stalling day to day now thats fine; Consumption went down to 15 after pump change s which is normal but now it reads high values and interestingly real world tank and odometer looks normal. My amp is still not working properly(low sound)and park sensors are also went down after amp. Injectors were reading high values so it is probably the cause.Will check them next week. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
Thanks for info. What did it cost?? They say all needles has to change is it false?? 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
I was charged £17 per injector to clean and test, and £135 less £17 ea to recondition the broken injectors.... with a full Bosch warranty!
