Home > Technical (L322) > Engine valve noise and high consumption.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
High
Gremlins are not leaving...
I have very high consumption 20-22litres for 2 days and start hearing valve shimming like noise from front of the engine.
It is a loud tapping noise.
Any ideas???
Post #424778 25th Jan 2017 6:57pm
holidaychicken
What vehicle and engine , I can't see it anywhere ?
How far and what sort of road did you drive in 2 days ?
Post #424820 26th Jan 2017 7:14am
umitbat
Sorry.06 td6 160k km.
One other thing is it sometimes not starts at first try engine hot or cold not an issue.
Which i never experienced at my 03 td6.
Daily route is mostly same with traffic normally 15-17 litres.
Post #424836 26th Jan 2017 10:28am
holidaychicken
I don't know much about the TD6 I'm afraid but others on here should be able to help out
Post #424982 27th Jan 2017 2:51am
Fuel, Oil or water consumption...???
We need as much info as possible, all other faults it has, does it still have the right power, any leaks, any smoke, colour etc etc... Pete
Post #424999 27th Jan 2017 8:39am
miggit
My TD6 got harder to start when it was hot, it didn't want to go one bit, turned out that I had some blocked injectors. I had all of them cleaned by a Bosch Service Centre and 2 were rebuilt with new needles and tips. after this had been done the car was back to normal again starting with a flick of the key Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425017 27th Jan 2017 10:20am
umitbat
God thanks i dont have 22 lt oil consumption!!!::)Only diesel!!!
Power is fine i rebuilt the intank pump it was stalling day to day now thats fine;
Consumption went down to 15 after pump change s which is normal but now it reads high values and interestingly real world tank and odometer looks normal.
My amp is still not working properly(low sound)and park sensors are also went down after amp.
Injectors were reading high values so it is probably the cause.Will check them next week. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #425108 27th Jan 2017 9:23pm
umitbat
Thanks for info.
What did it cost??
They say all needles has to change is it false?? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #425109 27th Jan 2017 9:24pm
miggit
I was charged £17 per injector to clean and test, and £135 less £17 ea to recondition the broken injectors.... with a full Bosch warranty!
I'd imagine that you can get them done for a lot less than that, as your not in the UK, just make sure that they are a Bosch Service Centre and you wont go far wrong Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #425148 28th Jan 2017 9:11am
