![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 ![]() ![]() ![]() |
Guys, I've done a bit of homework on these, as previous posts, I was unsure of the size & material.
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Does anyone know if this repair would be covered by LR Extended Warranty? |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
Should be as it's a failed part. Regards
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
What mileage can we expect to see this at? I have 69k and no sign. |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
Hi all my FF as got 93500 miles on the clock, and just starting to leak. Will do this next weekend
Hi all I am just about to do this, I spoke to LR today to get a torque wrench setting for bolt that secures the union HS4 It is torqued up to 10Nm. Hope this helps |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I replaced my O rings last night and in the process noticed that there is oil in my coolant, so it looks like I'll have to replace the oil cooler too.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
MJdronfield may be best bloke to ask as he had exactly that on his |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
What size o rings did you use? G reg 2.5VM Vogue Portofino red 1991- 1999
I used those suggested by Barry earlier in the thread: BS611 is a 8.73mm (ID Inside Diameter) x 1.78mm CS (Cross section) 'O' Ring.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
It's good to know that BS611 fits well - thanks for posting. |
Mpirie, good tip about taping first groove.
Bought a bag of 10.......
Lol, don't worry, I have 8 spares |
