| Diff Oil Confusion for 3.6TDV8 | |
Hi all, I am going to change the diff and transfer box oils but am a little confused as to which oil or quantity i need after reading numerous threads using the search function. Seems I have search overload confusion.
Front Diff Seems Standard Castrol SAF-OX - 75W/90 0.75 Liters so no problem there
Read Diff Seems to be Castrol SAF-OX - 75W/90 1.15 Liters for the Non locking rear diff (which I believe mine has as there is no mention of it on the build sheet) The confusion is that on one post they state the 3.6TDV8 needs the same quantity and oil as the 4.2 SC with locking rear diff which is a different oil so not sure if this is the case as other posts state the same oil for the 4.4TDV8.
Could someone please let me know if its the same oil for the front and back and if I buy 2 liters will this be sufficient?? Thanks in Advance.
