![]() | Home > Technical (L322) > fuel burning heater |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Behind the left front wheel inboard arch panel. John
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
As Weegie says, but you can't see if with the bonnet up unfortunately. I'm sure if your car is a TD6 it will have one fitted.
thegamekeeper Member Since: 12 Nov 2015 Location: sunderland Posts: 71 ![]() ![]() |
ile check again when i get home if its light. thanks all for your help and ile let you know Current. FFRR Vogue. TD6 Java black.
now ive just been out and had a look but i cant see no sign of it. should i not see it exhaust hanging down somewhere. has anyone got a picture of its location
The Td6 has a FBH. It is well hidden behind the wheel arch cover. You would need to either remove the cover or get underneath to have a chance of seeing it.
im a bit thick when it comes to stuff like that to be honest. i did try to set the timer on the auxiliary heater thing on the screen a few weeks back but nothin happened. is this the one you are referring to Current. FFRR Vogue. TD6 Java black.
AHA. i can see the exhaust for it sticking out. i need to try a few things now dont i Current. FFRR Vogue. TD6 Java black.
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 ![]() ![]() |
If its enabled, it could be in lockout.
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Gents
its 3 degrees today and it hasnt cut in so i will look into it more. here we go haha Current. FFRR Vogue. TD6 Java black.
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
The FBH won't operate if your battery monitor reads below something like 11.5 volts. Try again after fully charging your battery 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i |
well today i checked that fuse 59 for the heater and it had blown so i replaced it and tried the auxiliary heater settings on my screen (this has never worked) but i set it and it cut in but then ran for about 20 seconds and stopped. i checked the fuse just incase and it was ok. so what am i missing. does it have to be a certain temperature for it to work using the auxiliary settings
