Home > Technical (L322) > fuel burning heater
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
fuel burning heater
hi
i wonder if anyone could show me a picture or tell me where the fbh is on my td6. a few posts on here say every model has one but i cant see it. where should it be
thanks
tony Current. FFRR Vogue. TD6 Java black.
2009 Mini Cooper JCW in Black
Gone. 2006 Discovery 3
2008 Nissan Navarad40
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
2 x saphire cosworths
Various Mk1 & 2 rs Escorts (when i was young and mad)
Post #425786 31st Jan 2017 8:32pm
Weegie
Behind the left front wheel inboard arch panel. John
GAP iiD BT-Sold
Post #425800 31st Jan 2017 9:47pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
As Weegie says, but you can't see if with the bonnet up unfortunately. I'm sure if your car is a TD6 it will have one fitted.
I never knew my car had one until this winter... I went for a short journey to the shop and turned the car off but was making a weird boiler like sound under the bonnet and I had switched it off. Did some work on Google and found that it was just the FBH.
Great to know it has one, and that it does work Rolling with laughter
Post #425815 31st Jan 2017 11:41pm
thegamekeeper
ile check again when i get home if its light. thanks all for your help and ile let you know Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425829 1st Feb 2017 9:49am
thegamekeeper
now ive just been out and had a look but i cant see no sign of it. should i not see it exhaust hanging down somewhere. has anyone got a picture of its location
thanks
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425887 1st Feb 2017 6:02pm
Weegie
The Td6 has a FBH. It is well hidden behind the wheel arch cover. You would need to either remove the cover or get underneath to have a chance of seeing it.
If you go onto your touch screen you will find the way to set the timer to get it to run. John
GAP iiD BT-Sold
Post #425888 1st Feb 2017 6:06pm
thegamekeeper
im a bit thick when it comes to stuff like that to be honest. i did try to set the timer on the auxiliary heater thing on the screen a few weeks back but nothin happened. is this the one you are referring to Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425889 1st Feb 2017 6:11pm
thegamekeeper
AHA. i can see the exhaust for it sticking out. i need to try a few things now dont i Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425891 1st Feb 2017 6:17pm
Weegie
Thumbs Up John
GAP iiD BT-Sold
Post #425895 1st Feb 2017 6:28pm
thegamekeeper
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425902 1st Feb 2017 7:11pm
jonnyboy54321
If its enabled, it could be in lockout.
I have a lengthy thread on the go about mine Wink 2007 Vogue TDV8 with 255/55/20's fitted
Post #425906 1st Feb 2017 7:59pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Gents
One word.."Subzero"
Check him out Thumbs Up
Post #425914 1st Feb 2017 9:02pm
thegamekeeper
its 3 degrees today and it hasnt cut in so i will look into it more. here we go haha Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #425943 2nd Feb 2017 8:01am
TomCobbly
Quote:
Report post
The FBH won't operate if your battery monitor reads below something like 11.5 volts. Try again after fully charging your battery 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #425989 2nd Feb 2017 2:47pm
thegamekeeper
well today i checked that fuse 59 for the heater and it had blown so i replaced it and tried the auxiliary heater settings on my screen (this has never worked) but i set it and it cut in but then ran for about 20 seconds and stopped. i checked the fuse just incase and it was ok. so what am i missing. does it have to be a certain temperature for it to work using the auxiliary settings
thank you
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #426261 4th Feb 2017 4:49pm
